As you may be aware, the mud is much easier to remove when it is still wet, so the faster you get it done after your ride the less effort required and the more thorough a cleaning job can be.
Two situations that occur to me are the following, but I'm sure there are more:
- My outdoor hosebibs are located such that I shut down and drain the exterior water line to the hosebibs for the winter. However, that does not stop me from riding and so I often find myself with a muddy bike and no means to wash it.
- Sometimes I will drive (by vehicle) to a remote location and encounter sufficiently muddy trails. There is no place to wash the bike, so you load it back on your vehicle and the mud dries on the way home. This assumes there is no creek nearby to wash your bike in.
Remove these ads by
Signing UpStep 1: The Sprayer Solution
When using it at home on cold winter days, I fill it with warm water from the laundry sink.
For travel, just fill it before you leave home and leave it in your vehicle. so it's ready as soon as your ride is over.
I have found the pressure is adequate for removing wet mud and small debris quite well. The spray can be adjusted from a broad spray to narrow by twisting the nozzle end. The good thing about the light pressure is that you don't have to worry about spraying it into areas where you might worry about spraying a high pressure garden hose. Used in conjunction with a brush or two you can do a rather thorough job while out on the road.
Visit Our Store »
Go Pro Today »
Haven't tried it with soap mixed in yet.
I spray Simply Green on and scrub with a brush.
I'm glad it's working well for you.
