loading
Step 4: Software part - Compiling of the player for Raspberry PI
The most tricky part is to put correct libraries in the correct directory.
MANY THANKS to Aleksander Mosingiewicz (author of the player) for figuring out!
All commands are being executed as root.
Gain root access using command:
sudo passwd
Then you can log in as root by your password.
There are some packages to install before compiling:
aptitude update
aptitude install intltool
aptitude install libgtk2.0-dev
Preparation of source code and libs:
Put hardfp/libbass.so from bass24-linux-arm.zip in:
/usr/local/lib
Unzip source code:
tar -zxvf bassplay-0.1.tar.gz
unzip bass24-linux.zip in subdirectory bass in the directory of source code bassplay-0.1/bass.
!Do the same with bass24-linux-arm.zip and overwrite files!.
mkdir bassplay-0.1/bass
cp bass24-linux.zip bassplay-0.1/bass/
cp bass24-linux-arm.zip bassplay-0.1/bass/
unzip bassplay-0.1/bass/bass24-linux.zip
unzip bassplay-0.1/bass/bass24-linux-arm.zip
Proceed with compilation:
cd bassplay-0.1
./configure
make
make install
<p>Made it work with omxplayer for all music files (the software that is):</p><p><a href="https://github.com/iugamarian/bshplyr/tree/master" rel="nofollow">https://github.com/iugamarian/bshplyr/tree/master</a></p><p>Thank you.</p>
<p>It's nice to see that my project has been inspirative.</p><p>Can OMXplayer play MOD,S3M,IT,XM too? I cannot find this infromation.</p><p>It's good that it runs as service, too.</p><p>Do you plan to publish the final onstruction when it's done?</p>
<p>I don't have .mod files, test yourself with bshplyr-no-gpio my new smaller script (it seems I don't need gpio fo myself, just happy with automated play)</p><p>To play .mod you can also install timidity++ and change playerbin to /usr/bin/timidity++</p><p>If I have more time or someone else does we can make conditionals to change playerbin according to filetype (github allows changes, remembering history).</p><p>My final construction is just a Raspberry Pi in a cardboard case, adapted for battery pack according to </p><p><a href="http://www.daveakerman.com/?page_id=1294" rel="nofollow">http://www.daveakerman.com/?page_id=1294</a></p><p>with headphones and no buttons as GPIO's don't work for me for some unknown reason (they are always &quot;0&quot; ).</p>
Good Job! :) <br>Went to my Blog post: <br>http://faz-voce-mesmo.blogspot.pt/2013/01/prusa-i3-mais-rhinonest-cera-de.html
Could you add some information in the initial step explaining what MOD is and why a portable player is desireable?
Thank you for sharing your point of view. <br>I was driven by the logic that MOD enthusiast wouldn't need an explanation and people not knowing what MOD is wouldn't need MOD player. <br>I'll add a brief description with links to further resources. <br>Thanks again.
About This Instructable
32,365views
64favorites
License:
More by Mr.Holub:Smart mouse trap simple 6-wire communication protocol Portable native MOD player based on Raspberry PI (plays MOD,S3M,IT,XM etc...). Uses BassPlay library.
Add instructable to:
