3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable shopping cart locking force field OF DOOM
Have you ever been annoyed or even injured by evil sentient shopping cart attacks? well, now you can shop in safety! this belt will stop any hostile shopping cart in it's tracks if it comes within five feet of you! No more bruised ankles! no more threat of cart insurrection!
This life-saving device works by emmiting intense electromagnetic radiation that confuses the shopping cart and makes it think it has reached it's boundaries causing it to lock it's wheels in fear. don't delay, Build one NOW!
Disclaimer:
This is a proof-of-concept for educational purposes only, and may be illegal in some areas. this device also has the potential to really piss off store managers, so please use with discretion. i take no responsibility for the actions of anyone reading this.
You're going to need:
1 db9 female plug
1 db9 male plug
3 feet (roughly) of cat5 cable (or a serial cable)
1 headphone plug/wire
1 mp3 player
1 laptop or good quality recorder
Step 1Make the belt...
Make the belt...
First, cut a length of cat5 cable so it is long enouth to wrap around your waist (you can make it wrap around twice, if you want, but i didn't), but make it loose so you can work with it.
next get the db9 plugs, headphone plug and your soldering iron.
connect the cat5 cable's wires to the db9 plugs with the following pinouts:
male:
pin: | wire color:
1 Green stripe
2 solid Green
3 Blue stripe
4 solid Orange
5 Headphone jack
6 Brown stripe
7 solid Blue
8 Orange stripe
9 Not connected
the extra brown wire goes to the headphone jack
female:
pin: | wire color:
1 Solid green
2 solid Blue
3 Orange stripe
4 solid Brown
5 Brown stripe
6 Green stripe
7 Blue stripe
8 solid Orange
9 Not connected
151 comments
1-40 of 151next »
Feb 25, 2011. 4:10 PMSirStokes says:
What country is this from? I'm in the US and I've only heard preposterous theories about self braking shopping carts.
Mar 4, 2011. 12:16 AMTheIronHobo says:
i am in us and i have had a shopping cart lock up on me. look for a weird device on one of the wheels it looks innocent but it will brake it fast!
Sep 28, 2010. 5:35 AMatilladolphun says:
with reguards to the cathod ray tubes i used to work at a tv plant in tn even the brand new tubes hold quite a punch i had gotten shocked by them befor and it can be felt all the way up to the sholder though at that time it was just a stadic charge so no real amps in the tube but still got your attention.
Oct 3, 2007. 3:21 PMShinji says:
i just built one of these, and im so excited to try it i can hardly breathe... oh well. Amplifiers are very easy, just break open a tv and find an IC with only one side covered in pins, probably starts with "AN" (the # on the front) and look up the schematics online. I built one of these, and it just took an hour for a 3w amp. not amazing, but same principal i guess... T-elospathic
Aug 4, 2008. 4:37 AMthermoelectric says:
I'm 13 and i have pulled apart a CRT monitor, very cautiously, now im going back for more :)
Aug 4, 2008. 5:18 PMthermoelectric says:
i'll never die doin this
Aug 8, 2008. 7:45 AMDigital_Anarchy says:
famous last words...
Jun 2, 2010. 7:37 PMCybergothiChe says:
 lol
Aug 8, 2008. 4:09 PMthermoelectric says:
lol
Aug 9, 2008. 8:33 PMFrogz says:
i took apart my first tv when i was like 12, not all models use the same amp ic infact, alot of them will use a lm class amp(or other) there is no sure way to tell what the amp chip is but any stereo, tv, or other device with speakers(ie, not ONLY a headphones jack) will likely have an amp in it old boomboxes are perfect as the amplifier circuit generally can be tapped into with 2/3 wires and leave the circuit intact
Aug 9, 2008. 10:57 PMthermoelectric says:
I have a RGB amplifier out of one but i don't know what to use it for.
Here's a link to it if you know what i can use it for
Aug 10, 2008. 6:25 PMShinji says:
The amp ICs that are independent are actually very easy to identify. They have a lot of pins and are usually SIP, mounted to a good sized heat sink, depending on the wattage it puts out. I will happily answer specific comments if anyone wants to ask. The ICs can be found in just about any monitor or TV with speakers, but boom boxes and stereos use whole circuits to power the speakers, so you do have to leave it in tact and switch the inputs and outputs. Just remember: when in doubt, Google the # on the front of the chip! And btw, unless you are working on a gigantic TV with an abnormally huge flyback, there is NOT enough current to kill you! Seriously!
Aug 10, 2008. 10:07 PMthermoelectric says:
Yea, I agree there isn't enough current but it will still feel like you were run over by a truck
Aug 11, 2008. 1:11 PMShinji says:
Ha yeah it does, about a year ago I slipped and jabbed the suction cup with a screw driver not so well insulated... Thats a nasty shock, like if you jumped on a trampoline for 3 years then touched the side of it.
Mar 29, 2009. 8:09 PMtaz9797 says:
how many replys are there going to be lol =)
Mar 29, 2009. 10:09 PMthermoelectric says:
Yeah...
May 1, 2011. 9:03 AMAdam Manick says:
yeah
Dec 21, 2007. 8:23 AMbioerror says:
I Agree, and handling the Cathode Ray Tube in the wrong way and you drop it, it may EXPLOED!! If your going to use parts from a older tv always, always remove the thick red wire that looks like a suction cup (its about half way down the Cathode tube(towards the part you watch CSI: MIAMI on( by removing this wire you let the gases inside the tube to escape))) also for added safety remove the wires at the small end of the tube. And always remember UNPLUG IT FIRST BEFORE OPENING THE CASE!!!
Jul 6, 2008. 1:02 PMmannys9130 says:
removing the tht (suction cup) will not cause any gasses to escape, in fact, the tube is a vacuum and there is no gas in there. If I had listened to your advice, i'd be in the hospital with arterial fibrelation!
Dec 18, 2009. 10:36 PMbioerror says:
well you would if u either left it plugged in or opened it right away cuz the CRT can still hold energy after sitting unplugged for a few days, 30+ days should be enough time for the power to drain off.
oh and my dad told me there was gases in a CRT, and my dad is known for being incorrect 80% of the time
Dec 19, 2009. 4:49 AMShinji says:
The CRT is a vacuum. It may not be a perfect vacuum, because of manufacturing error, but it is not filled with gases. Sorry daddy, but this is part of that 80%!
The one that shocked me was unplugged ~5 minutes before electrically assaulting me. The CRT does not hold energy, and the amount of capacitance that the flyback has is likely lower than 5 pF. That's hardly anything. What holds charge are the capacitors that supply/buffer the flyback circuit.
This is a long thread. This is awesome.
Jun 11, 2011. 2:48 PMGameNox says:
I took apart a TV and i didn't get shocked. There are 3 facts I found:
1. The CRT is a vacuum, it is also known as a vacuum tube.
2. It is not filled with gasses. Why would they even think of putting neon or another noble gas inside a TV?
3. TVs won't shock you as long as they are old and aren't plugged in and all the capacitors are empty.
Sorry bioerror it's 3 against 1...
Jul 6, 2008. 8:28 PMbioerror says:
The comment I made is on Info I have heard (in other words Second-Hand-Knowledge!)
Jul 7, 2008. 11:28 AMShinji says:
Well, now you know :)
Jul 6, 2008. 2:42 PMShinji says:
The red wire is a BAD thing to play with. unless you like 15-30kV coursing through your body, don't touch the suction cup. All I am saying is that TVs are a good place to find these audio amp ICs, because they are small and self contained. TVs aren't scary, just the red wire should not be messed with unless you discharge the capacitors. Simply put, just don't touch the Red Wire .
Jul 5, 2010. 1:40 PMCameronC says:
Google how to discharge a CRT safely - theres also a few instructables about it. Also don't try to remove the suction cup unless you 1) know what you're doing and 2) Have already discharged the CRT. Having your hand stuck on to a glass tube that is electrocuting you (Unlikely, but meh) doesn't sound too fun.
Jul 14, 2008. 9:22 AMDerin says:
or the pink
Dec 18, 2009. 9:12 PMstruckbyanarrow says:
you forgot the yellow
Dec 19, 2009. 4:51 AMShinji says:
umm... The yellow? I think it wasn't us who forgot it, but all the manufacturers..
Dec 19, 2009. 10:29 AMstruckbyanarrow says:
i was kidding :D
Jul 14, 2008. 1:45 PMbioerror says:
Pink?!?! i've never seen any pink wire going to the flyback transformer.
Jul 14, 2008. 11:15 PMDerin says:
the pink is not on CRT televisions,its the hi-voltage anode for a CCFL in a LCD
ok too much terms...may i shut up now
Jul 18, 2008. 2:35 PMShinji says:
True, the only place I have noticed pink is in LCDs. Still high voltage, but only when on. and not near the amount of power as in a flyback.
Jul 6, 2008. 3:23 PMmannys9130 says:
all you have to do is stick a grounged piece of metal under the suction cup to discharge the tobe and anything left in the flyback. the red wire carries high voltage while in operation but if you discharge the tube and board, nothing will happen if you touch it. I have taken apart several crt moniters and have not seen any person that has been electrocuted after they discahrged the tht. Use insulated pliers to push a peice of metal that is grounded under the suction cup. you could also use a grounded screw driver. It is totally safe after discharge... you did unplug the cord from the wall... right?
Jul 6, 2008. 6:43 PMShinji says:
It's nice to see someone who isn't afraid of Tvs... Like he says, all you have to do is ground a screwdriver via a wire going into the ground hole of an electrical wall socket, etc. and poke it under the suction cup and touch the piece of metal under it. Cathode Ray Tubes really aren't much to be afraid of.
Aug 4, 2008. 4:39 AMthermoelectric says:
exactly, im 13 and pulled apart many in my short life (without getting the slightest shock :) )
Jul 5, 2010. 1:43 PMCameronC says:
Try shooting a discharged crt with an air rifle - Just do it from a distance and put something to collect the glass eg thick tarp and 5 sided box made of concrete slabs. IMPLOSION!
Jul 6, 2008. 7:17 PMmannys9130 says:
exactly. tv sets are not scary at all. If you know what your doing and you take the procaution you will not get a lethal dose of electricity. Take caution and stay away from things unless you are properly insulated of you have discharged the electricity and the inside of the tv will not pose any threat.
1-40 of 151next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:joe57005
My name is Joe. I enjoy long walks on the beach, pina colladas, getting caught in the rain, playing with dead things, playing with fire, hacking, programming, reverse engineering and blowing stuff up....
more »
