3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable speaker in a CD case!!
Have you ever thought of making your own portable speaker in a CD case? Here is how you do it.
Step 1Components required
Components required
- 8W speaker with 4 ohms impedance (Make sure the speaker's impedance must match your amp's specification or you would damage your amp!!)
- CD case ( Use the one with a zip would be good)
- 18W Amplifier module (I used the Kemo #M033, you can use other amplifiers as long as the Watts are not 2.5 times larger than your speaker's power level)
- Rocker switch
- 3.5mm stereo adapter
- Battery snap and a 9V battery
- Solder iron and some solder
- Glue gun
- Cutting knife
- Drill
Note that:
If you choose an amp that is supplying too much power to your speakers, then its clear that there is a chance that you will damage them. It may cause the voice coil to overheat, or the speaker could move back and forth too much (known as exceeding its Xmax).
However if you have a smaller amplifier you may have to run it all the way up full to provide enough power to your speakers. When running at full blast, there will be lots of stress on the components of the amps and it can introduce a significant amount of distortion into your signal, which is often called 'clipping'.
As well as sounding very bad, trying to reproduce a clipping signal can potentially do far more damage to your speakers that a little too much power.
Therefore the unwritten rule is that you should have an amplifier that is capable of 1.5 to 2 times the power rating of your speaker system, and only turn it up part way. The extra power available is called the headroom, and means that your amplifier should never been running at full tilt and therefore producing a distorted, or clipped, signal.
124 comments
1-40 of 124next »
Apr 24, 2012. 12:04 PMhajk says:
Hello!
I wonder if i can make it work with a 80 Watt speaker?
Apr 27, 2011. 11:22 PMKodak88 says:
I would recommend not putting the iPod inside the case, as the magnets from the speakers could mess with your iPod's memory! Just a thought.
Jul 20, 2011. 2:51 PMT0C says:
Nah it won't... these days electronics almost aren't effected by magnets (excluding CRT monitors), here you don't have a tape to blank when you run a magnet by it :D. it's all just thousands and thousands of transistors (in chips of course well by that i mean , let's say you have a cpu in one of the older versions i remember there are about 73 mil. transistors and that cpu is from 2001 i think so....)
Jan 3, 2012. 2:04 PMbigjeff5 says:
Just wanted to give you some updated numbers:
The Tegra 2 (used in many smartphones but is being supplanted by the Tegra 3) has 260 million transistors.
Most modern desktop CPU's have between 250 million and 1.2 billion transistors, while server CPU's can have up to 2.5 billion transistors.
Modern desktop GPU's can have up to 4 billion transistors.
Most people will never encounter an FPGA (a sort of reconfigurable CPU), but they can have just shy of 7 billion transistors.
A gigabyte of DRAM (the kind of ram in smartphones and PC's) has about 8 billion transistors.
A gigabyte of Flash memory has either 8 billion (SLC) or 4 billion (MLC) transistors.
It would take a horribly powerful magnet to mess with any of it, since they all off specific electrical signals at certain voltages which are incredibly difficult to generate by accident with a magnet. As you pointed out the magnets were a concern for certain magnetic storage technologies. Even then, while a floppy disk could be damaged by an errant magnet in the pocket, even modern magnetic hard drives require much more powerful magnets to destroy the data without physically touching the platters inside (hard drives actually have quite powerful magnets sitting right next to the platters which don't affect the data at all).
Simply put, it's not likely you'll be able to get your hands on a magnet powerful enough to hurt your smartphone, and you most certainly won't be able to get that magnet to fit in your pocket.
Jan 9, 2012. 8:20 AMT0C says:
Yeah, the cpu i mentioned wasn't from 2001 but from 1991 or so lol.
About the hard drives, i've seen the magnets inside and they're really powerful but as you said they can't erase the data, to erase the data (and probably completely destroy it) it would take a magnet about as powerful as an MRI or something bigger.
There's always a way :) and most of the time it's fun as hell!
Dec 29, 2011. 7:32 PM#OccupyInstruct says:
hows the sound? assuming that your using a subwoofer the bass should be outstanding
Dec 9, 2011. 10:50 AMrohaanwadia says:
so if i am using 2 8watt 4ohm speakers then is a 30watt amp appropriate??
Jun 19, 2011. 10:58 AMjholley1 says:
i bought one like this but allready built
Oct 15, 2010. 6:33 AMkrayola says:
panalo to dre! hehe gumawa din ako nung little gem and MKII na guitar ampli. this site is the best.. the ideas are the best..
Oct 13, 2010. 7:08 AMASCAS says:
I would try to link you on a site where to buy a 4 inch 20W speaker 4 ohms. I already have one and here in our country (philippines) it only cost $2 in php-dollar converstion. The speakers give a high quality BASS, MID RANGE and TREBLE. Its worth every penny. I could even be sold for $100 because of it's quality.
Mar 16, 2010. 10:17 AMdhvinay says:
pls suggest me where to get the amp from...
any preferable online websites ?
Nov 4, 2009. 5:53 PMLkArio says:
That's nice, but 18W is too much for such a small speaker.
Apr 8, 2009. 7:42 PMmusick_08 says:
how would you do this without the amp. ( I'm new to electronics.)
Oct 5, 2009. 12:20 AMAkKrock says:
In my opinion: You can't feed speaker without amp. You could burn your device output.
Oct 5, 2009. 2:41 PMmusick_08 says:
ok thanks. i thought it would, but i wasnt sure.
Aug 21, 2008. 10:03 AMrecovering me says:
ok i'm worrying bout something, surely if you are running the power from the 9volt through the stereo jack, it is being pumped into your ipod of mp3 player, doesnt that do damage to it? also, are the stereo jack, battery and switch in series on the input circuit?
Sep 11, 2009. 8:41 PMJonas412 says:
of corse you could put a diode from th 9V
Sep 11, 2009. 8:36 PMJonas412 says:
You could just make a simple aplifing curciut with transistors ans a potentiometer
Aug 25, 2009. 6:40 AMraikut says:
But what if we don't get this type of amp in our country
Jul 2, 2009. 9:09 AMbasketballer904 says:
it would be cool if there was a pot for a higher volume control other than what is on your I-Pod.
Apr 16, 2008. 10:27 PMseraph says:
would a 15w speaker work with the 18w amp? and also, where can I buy most of these components... do you think radio shack would have it?
Jun 28, 2009. 4:22 PMbigern71 says:
check a hobby store also
Oct 7, 2008. 1:11 PMDark JoJo says:
it might though, radio shack has everything.
Jun 24, 2009. 2:18 AMCybergothiChe says:
that's sweet...but what are you doing with a cd case if you have an Ipod?
Jun 24, 2009. 2:19 AMCybergothiChe says:
ok, scratch that...I din't realize how big the speaker magnet was...but still sweet
Jun 11, 2009. 11:58 AMarmynavy17 says:
Ok so I'm thinking about doing something like this but with two speakers. They are both 1W 4ohm speakers. I want them to still be stereo so do I need two amps? Should I use a 2W amp(s) or something else?
Jun 11, 2009. 12:09 PMarmynavy17 says:
Or if I didn't have it stereo and I ran them both off of one amp could i use a 3.5W amp?
May 11, 2009. 12:23 PMcomodore says:
Can you make this operate 2 speakers like 2 head phones? Great project man! I love it! PS: comment number 101! hehe
May 11, 2009. 10:19 AMdjshalford says:
its been a while since i studied but if the two left and right signals are being combined pre-amp it shouldnt need the resistors? (or is that to stop any distortion?) and i have a double cd case and im thinking of doing a double speaker version since this design only puts one signal through amp (if it works) then should be able to double up on everything except stereo jack... i.e using the two mono signal amps two speakers two switches connected as seperate circuits with negative of batteries to negative inputs of individual amps and those connections connected together at the ground terminal of the stereo jack and two different signals (left and right) going to seperate amps and concurrently speakers. Please comment on idea usefull feedback might jog my memory to whats being missed in the circuit (besides a fuse) ... thank u
Apr 6, 2008. 10:08 AMcreative zen says:
wow, i wanna make one...A few questions though. Where can I Obtain these supplies, and how much would all this cost to make?
Nov 3, 2008. 10:53 AMinventor matt says:
it would cost about $2-$6or$10 you can get the supplies on ebay,radio shack,dump or junk yard for parts from cars old radio and also from old toys,radio. i got lots of parts at home
Apr 14, 2009. 11:34 AMDa Nugesta says:
Plz reply i luv the mini carbon cone woofer!
Feb 22, 2009. 9:04 AMDa Nugesta says:
Nice Speaker M8 where did ya geddit from huh??!! I like the carbon Cone
Oct 7, 2008. 1:08 PMDark JoJo says:
i already have enough speakers though it's just having the speaker right in the open on the case it will wreck it thought. What if like water get spilled or if you drop it? then you're screwed. You can obtain these supplies at any place like Wal*Mart or like Totem or even an electronics store and it depends on the brand the more expensive brand the more money it's gonn cost you.
Apr 10, 2008. 12:02 PMcreative zen says:
what does this mean? £. Can you convert that to U.S. currency?
Oct 7, 2008. 1:10 PMDark JoJo says:
so how much would that be?
Nov 3, 2008. 10:39 AMhurtzmyhead says:
about $24
1-40 of 124next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:fatrickuk
