Portable Speakers / Speakers on Battery
Introduction: Portable Speakers / Speakers on Battery
Hi guys.
This is my first instructable. Enjoy!
So today I am gong to show you how to make from old pc speakers to speakers on battery.
It's pretty basic and I have a lot of pictures. ;)
Step 1: Items You Need
The tools you need:
-A cross screwdriver
-A 9v battery
-A 9v connection thing, see picture (don't know how to call it)
-A soldering iron (not nessecary)
-A hot glue gun (not nessecary)
Step 2: Open the Speaker
Now open the speaker using your cross screwdriver.
Step 3: Taking Apart
Now take the board what everything is connected to, and you will see a couple of wires: One for the otherspeakers, a pair for the wire of the speakers and one for electricity. Thats the one we need.
If you watch, u will see the electricity wires russing to the AC/DC adaptor, and then to your plug.
Then take your screwdriver, and screw the adaptor thing out.
Take your your pliers and cut the wires that are connected to the the two plastic tops.
Now turn your adaptor out and you'll see a sticker with the volt and the amp�re you need to use it.
Mine was: 9v and 0.6A.
Step 4: Connecting the Wires
Now cut the 2 wires that are leading to your electric board. Strip them.
Mostly, the left one (the first one) is + and the right one is -.
You also can check it using the volt meter.
Now mark your + and take the 9v connector, the red one is + and the black one is -.
Solder them together.
Then take some tape (I didn't find my electric tape, but duck tape will do the job ;) and wrap it around the place where the cables were soldered.
Step 5: Removing the Plug
Now we have to deal with that plug.
Its pretty simple.
Turn your speaker over.
Then take a nife or something and try to pop the plastic open that's holding the wire from the plug.
Step 6: Close It Up
Now attatch the battery to the 9v connector.
Use your hot glue gun if you want to make sure everything stays in place.
Then screw the top back on.
Step 7: Final
Your speakers are now officialy portable. Tough mine are to big :D.
Now show everybody your new portable speakers, and add a comment :)
Thank you for reading folks!
3 People Made This Project!
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Paper Contest 2018
    Paper Contest 2018
I made a speaker that seems to have the volume of headphones since all I did was grab a speaker some cable a jack and I glued it all together but I don't like the volume it has. I want to add a litinium battery with the cable but I feel like that will fry the cable and speaker anyone know how to max the volume
how long does battery last??
i think 12 volt can make more higher until 24 v dc coz of the concern of the transformers coz poor quality mean lack of crank the boost of your speaker so can but should check the cap if the volt more over to 50 to sure your capacitor is not been explode and make your speaker not been unusefull
You sir are a genius. Detailed instructable, organized steps. I favorited it!!
This instructable is great but the 9 volt connection thing is called a battery clip. I am one of your followers because of this great instrucable.
Your instructions are great. Just wondering, did you detach the wall wart from the speakers all together? Did you hook up the battery right with the chip or did you attach the battery to the wall wart, and then to the chip. My speakers turned out to be AC not DC so I'm a little confused on what to do.
You have to get rid of the wall wart. Just connect the battery wires to the wires that are left from the wall wart. It'll just be a clean DC to DC connection.
are you danish?? its a danish/german plug.. if so then you will understand this DET ER BARE FOR FEDT!!! det virker fint men jeg bruger 12 volt og 2 9V batterier med end begrænser til 9 fordi det holder meget længere(jeg gemmer batterierne inden i)
its a european plug
