Portable speakers / Speakers on battery by st0rm
Step 4: Connecting the wires
Now cut the 2 wires that are leading to your electric board. Strip them.
Mostly, the left one (the first one) is + and the right one is -.
You also can check it using the volt meter.
Now mark your + and take the 9v connector, the red one is + and the black one is -.
Solder them together.
Then take some tape (I didn't find my electric tape, but duck tape will do the job ;) and wrap it around the place where the cables were soldered.
Arano says: Mar 21, 2011. 1:09 PM
those 2 wires are both + and -... the 4 diodes in the up/left corner are a rectifier so you cant wire a batterie to those wires in a wrong way
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
