Portals: A Networked Mixed-Reality Playground by zephyrbunny
Contest WinnerFeatured
Portals is a prototype of a tangible and networked system/interface for interacting with a virtual world.
A portal, according to Wikipedia, is a magical or technological doorway that connects two distant locations separated by spacetime. Places that a portal will link to include a different spot in the same universe, a parallel world, the past or the future, and other planes of existence.
There are basically 3 main features of these specific portals:
1. To interact with the portal, you reach inside the box, going behind the screen instead of gesturing in front of it or touching it.
2. The two portals are networked so you can collaboratively play with someone in a shared space, even if they're physically far away.
3. The system recognizes and responds when special objects are inside, tracking the id, position, and rotation.
Videos
It makes more sense when you see it in action, so here's an edited version of a longer scenario video I made for the project which just highlights the main features.
Also, a short video of the Portals in action at 4 Hours Solid, my grad show:
The project was created in 2011-12 as part of an MFA Thesis in Graduate Media Design, at Art Center College of Design. If you want more details about the project visit Portals (and friends). One of my main goals of the project was to create something that other people could build upon and expand. So.... without further ado, let's get on to the How To part of things!
Note: my process of building these boxes wasn’t this straight forward. It was a super iterative process that involved lots of small tests. Even though I’m going to try to explain it in a more logical step based way, I would still recommend testing out parts of the hardware + software before diving in and building the entire thing for real.
“The visible world is no longer a reality and the unseen world is no longer a dream.”-Arthur Symons
Step 1: Supplies
1. MATERIALS (for a pair of Portals)
What you use to build the physical enclosures/structures is up to you really. And how much of it sort of depends on how big your box is.
• 1x sheet of drafting velum To diffuse the light box light.
• 3x 1/4” white acrylic (18” x 32”) To build the light boxes + poppets
• 2x 3/8” plywood (36” x 48”) The main cases
• 1x 1/8” plywood (18” x 24”) For the camera + light mounts
• 4 tiny hinges. For the box lids.
• 2 sheets of clear address label stickers Avery 1” x 2 5/8”
• Misc. adhesive + cutting supplies. A roll of velcro, white tape, elmer’s glue, acrylic cement, small screws, x-actos, laser cutter, woodshop, etc...
2. ELECTRONICS (for a pair of Portals)
They're not exactly cheap..
• 2x Newer iMacs. Running OSX 10.6.8. a newer/faster one is probably better.
• 2x flat-screen LCD monitor. I’m using 17inch Acer monitors with removable stands
• 2x display port to VGA adapters To hook up the monitors to the computers
• 2x HD webcam I’m using Logitech c910. Color and quality is great but there’s no manual control for anything which sucks. But the HD cams result in a pretty clean chroma key. I am definitely still inter- ested in an acceptable alternative to these cameras.
• 2x board camera with remote CCD Unibrain’s Fire-i Digital Board Camera with Remote CCD. These are Firewire and have a manual focus as well as an interchangeable lens.
• 2x lens for the Fire-i cameras 2.1mm seems to work alright for this distance.
• 2x firewire 400 to 800 adapters For the firewire cameras
• 2x set of ultra thin LED puck lights I have some by Amertac. One set contains 3 lights.
• 4x set of Ultra Thin LED strip lights Amertac. One set is 3 strips, you need 12 strips total.
• 1x power strip/surge protector
3. SOFTWARE + FILES
I’ll go into more detail about each of these later, but we’re basically going to be connecting all of these things together.
• Reactivision (http://reactivision.sourceforge.net/) Open source computer vision framework
• Osculator (http://www.osculator.net/) Interprets OSC messages
• NETLab Toolkit + HUB (http://www.netlabtoolkit.org/) Integrates tangible interaction + Flash
• Adobe Flash CS5+ (http://www.adobe.com/downloads/) You know. Flash.
• iChat (comes with your mac) Handles the video chat side of things
• CamTwist (http://camtwiststudio.com/) Layers all the video feeds together.
• Files (http://portals-and-friends.com/share/Portals_Files.zip) Includes program files, laser cutting files, and artwork
instructamaker says: Mar 6, 2013. 5:20 PM
THAT IS SO AWESOME MY LITTLE BROTHER WOULD LOVE IT:D
thealeks says: Jan 30, 2013. 5:41 PM
What about skype instead of the camtwist program? Its available on most platforms and allows for plugins to enhance tue whole deal. Just a thought.
Awesome work though, instructables like this are what makes me love this site so much. So much ingenuity and creativity. Keep up the awesome work!
thealeks says: Jan 30, 2013. 5:44 PM
Sorry actually skype would replace ichat. But maybe a plugin could be written to replace camtwist as well.
videogame57 says: Jun 9, 2012. 7:56 AM
Is it necessary to use an iMac, is the software or something similar available for windows and/or linux?
zephyrbunny (author) says: Jun 10, 2012. 4:45 PM
I suppose you could use something other than a Mac, most of the software works on Mac or Windows.
CamTwist, which is what sort of makes the magic happen is for Mac only. There are other similar programs out there for Windows but I don't know which ones would work best since I haven't tested for it. But let me know if you find a good one!
saibeck82 says: Aug 15, 2012. 10:39 AM
I like to make this project for my own. but the software's is the problem, all of it need to use mac operation.. is there any software's that can be use for window or Linux.... please help me please. i already buy the components.
milkywaybar says: Dec 25, 2012. 10:05 AM
I found this, didn't know if it will help or not.
http://www.pcwinsoft.com/screencamera/
alinke says: Dec 23, 2012. 1:48 PM
wow! absolutely amazing, wonderful idea and execution!
synthdust says: Aug 11, 2012. 9:00 PM
This is beautiful!!! It would be awesome if you had several locations linked up, throughout a city, or in several cities. Very very cool. So many possibilities.
Culturedropout says: Jun 5, 2012. 9:23 PM
Very cool idea, and an excellent implementation. I love watching "adults" play without realizing they're doing it. :-)
zephyrbunny (author) says: Jun 10, 2012. 4:50 PM
Thanks! Yeah the best part of the project is seeing how people of all ages play with it.
redsunmtm says: Jun 7, 2012. 10:58 AM
super cool idea, you should test with kinect, really amazing capturing device, available for PC and mac with the SDK (drivers included) or also EyeToy, same way ! and all that for free....
zephyrbunny (author) says: Jun 10, 2012. 4:49 PM
I thought about the Kinect for this but unfortunately it doesn't work very well for close up tracking, which I needed for this scale. But I'd love to play with it more for other projects.
Treknology says: Jun 10, 2012. 9:09 AM
I would like to see two hands in different 'portals' interact with each other... that would be freaky!
zephyrbunny (author) says: Jun 10, 2012. 4:47 PM
When playing with it, people do often interact with each other and play as if they're in the same space.
the poodleo says: Jun 10, 2012. 11:42 AM
this is the only reason i am taking any electronics classes in high school.
zephyrbunny (author) says: Jun 10, 2012. 4:46 PM
: ) Awesome you get to take electronics classes in high school. I wish I had that opportunity!
angelabchua says: Jun 7, 2012. 10:10 AM
W-O-W... Wow....
GENERALCHAOS says: Jun 7, 2012. 1:45 PM
indeed " WOW " that so sic yo i want 1 now >.<
ynze says: Jun 6, 2012. 12:47 AM
Smart and clever and fun!
Eldjotnar says: Jun 5, 2012. 6:36 PM
This is so awesome. Nicely done!
fozzy13 says: Jun 5, 2012. 6:14 PM
This is so freakin' awesome!! : )
tinker234 says: Jun 4, 2012. 1:36 PM
i read about virtual texturtes this seems to have a lot of potianel i wonder if that could be added lallter in the futre great job love the portal
Xthinker says: Jun 4, 2012. 12:22 AM
OH MY GOD! That's freaking amazing.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
