Portrait Monitor Easel - Designed by Apple in California.
13,478
19
62
Posted in TechnologyApple
Introduction: Portrait Monitor Easel - Designed by Apple in California.
About: I am a British Graphic Designer and Photographer, when I am not working, I spend my time making an array of projects. I used to make a lot of props, but now I spend most my time building crazy cameras and sh...
This a quick one, so simple, and great I had to share. For the past week I have been thinking about setting up my second screen in portrait mode.
Mac OS X supports easy resolution rotation of most monitors, i had already flicked the switch and tried it.
The main problem, my monitor was a 'media one' and came with no form of VESA mount. So i decided the best solution would be to make an 'Easel' of sorts, to hold my monitor as if it was a painting.
Here is how i did it.
Step 1: Finding Some Good Items.
I had recently picked up a cheap stand off the back of an iMac, i figured due to its solid construction this would make an ideal stand.
I was stuck for how to make the monitor remain still. At this point i remembered that i picked up an iMac VESA adapter kit.
Both of them are made of hefty aluminum, they both read, Designed by Apple in California.
Step 2: ULTIMATE DOUBLE SIDED TAPE
Next I needed to combine the two items, thus i introduce the ULTIMATE DOUBLE SIDED TAPE
I purchased this tape during my PC modding days, its a great super strength double sided tape, its made of like a plastic gel stuff. It easily holds several pounds.
I saw i used to hold perspex windows inside PC cases, i spent 50 GBP on this massive roll of the stuff.
Step 3: Apply the Tape
I applied three strips of the UDST (ULTIMATE DOUBLE SIDED TAPE) to the underneath of the VESA mount section.
I then worked out the correct place to attach the VESA mount to the stand, i marked it with masking tape, so i could place it perfectly.
The tape is super strong, and will never budge, especially on metal like this. However, the tape can be removed and leave no marks.
Step 4: Stick Them Together!
I carefully peeled back the strips from the double sided tape, the best thing i have found for this is to use the back of an X-acto or scalpel to peel it off.
Carefully line up the pieces by eye, and place, press firmly.
You can see the tape easily holds the two pieces together, the picture shows how the tape supports the weight of the stand easily.
Step 5: Finish.
Thats it, i knocked the stand of the monitor, and sat it nicely on one side.
The final stand is very stable, and the aluminum matches in with the rest of my apple goodness.
A simple Instructable, but as you can see, the portrait screen, running at 1050 x 1680 is the perfect proportion and resolution for viewing web pages.
Just look how much of the instructables front page fits on there?
Instructables needs to be viewed in portrait, just like the rest of the internet.
As you can see, Picard approves.
- gmjhowe
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    62 Comments
     Thats good and i think thats the same tv i have... but i use it for my xbox and i think i would struggle with the xbox on the side lol... i have another cheapo 15" one i might just mount above my mac so i can see it easier from my bed :D
    Is it just me or is everyone else thinking the same thing, for 800 pound i can get a imac but for half that i can get a better pc, i just recently bought a intel quad core system for 400 quid yet if i had got a mac at double the price i would have got half the power as they only have dual cores, they seem to be very overated and overpriced.
    I have my reasons for using an iMac, as a professional i know exactly what i need, and the iMac provides. Also, im guessing your making the usual mistake of comparing a slimline all in one PC, with a standard tower pc. The iMac is also made of aluminum, the quality of the screen alone is equal to that of a £400 LaCie screen - so the screen kinda makes up the price without taking into consideration the form and size.
    Aha, Pc's range in so many brands and materials, That that reason to buy a mac would be invalid, PC's are also made of metals(like aluminum) and high-quality plastics. And the screen, Also Invalid.
    No, because to buy a pc made from aluminum, and with the lacie screen, it works out about the same.
    So? Imac screens aren't any better than the 300$ 24" Screen I bought.
    Sure, it's LED, and uses a lot less power/makes less heat, but it's not worth 800$
    It's just apple being greedy.
    A while ago you could buy macs from other companies, that were better and much more powerful, for a fraction of the cost, but apple wasn't making enough money. It's like how they charge 400$ for an Ipod, that probably cost them less than 50$ to make.
    I just think that it's apple charging tons of money for the OS, and leave it at that.
    Macintosh is a way better OS, but for 1000$ I bought a desktop and Full HD plasma monitor, that has:
    More Memory,
    Better graphics,
    a Better sound card,
    More USB slots,
    Bigger Hard drive,
    and has a way better processor
    than my 2000$ Imac.
    The only thing that the Imac does better is it has a way better wireless network card.
    I prefer the Imac, but for a lot of stuff, the desktop is much better.
    Same what? Also, A metal casing is dangerous, You drop it, and the insides crumble, You bend it, And it shorts out, You touch a hot part(like near the CPU) you burn yourself and drop it, not to mention it would end up heavier.
    + Macs are beautiful !
    You know you need it. Thats only three screens worth of scrolling for me to read all that..
    Unless you want to buy it for me it'll have to wait plz plz plz plz plz plz plz plz plz
    haha, the macbook runs a 1680 x 1050 screen with great ease as well!
    Yeah, I know, but I don't feel like spending over $150
    I paid £160 for that monitor about 1.5 years ago! You can get it for about £90 You could get a 17" widescreen?
    I said dollars, not pounds.
    I'm using a 21" acer monitor I got for $200 a few years back, its quality is so-so but overall its pretty good (not the best for post image processing though)
    I know, i was expecting you to convert it.
    ~129.95 Still more than I can afford right now
    Thats why it might be best looking for a 17" widescreen
