loading
Here I show you how to make origami icosahedron from 30 sonobe pieces.
Step 1: Fold post-it in half glued side inside
Step 2: Fold bottom and top in the center
Step 3: Fold both corners on the upper line
Step 4: Wrap it up
Step 5: Fold the corners over
Step 6: Make a square and fold it into triangle
Step 7: Make 30 sonobe units
Step 8: Place three units together to form a triangular pyramid
Make them in cycle of 5.
Step 9: Build it - it's like a puzzle
Just form triangles and you will see form shaping.
Step 10: Alternative method for building
You can also build 2 cycles of 5 pyramids separately. In one of them connect middle from pyramids and then connect the top from ready cycle of 5 pyramids.
Step 11: Now you have nice modular origami to decorate your desktop
<p>I love this</p>
<p>I love how this looks, It's so bright and colorful!!!</p>
<p>I got stuck when I was trying to put it together, but then I finally got the hang of it after an hour.</p>
<p>Will it still work if I use origami paper?</p>
<p>I got a little stuck on trying to put it all together although slowly but surely im getting it done and figuring out how it goes</p>
<p>If was kind of hard but I got it all the piece to fit together, I feel so accomplished. </p>
<p>I made it! A bit unstable, but otherwise pretty good!</p>
Last step..... Building it...... Easier said for sure. I have a lot of trouble.
Connecting can be a little challenging sometimes. Just connect pyramids together in cycles of 5. It will begin to curve into a ball or start with cyckle of 5 pydamids and turn it over. Then add units in the &quot;side/middle&quot;. To close icosahedron you will need to connect pysramids next to each other and then add in the gaps more units. In which part did you had trouble?
I'm confused on how you would make the pyramid shape. I have 30 of them sitting in front of me. I just can't make out how you did it...
I added new step 10 with alternative method.
<p>is awesome..........!!</p>
I've done this with notebook paper and it's a little different. Step 4 loses me. I understand the first fold. Then the picture of the second.... Lost
About This Instructable
127,405views
117favorites
License:
More by Pavelos:Post-It Origami Icosahedron Installing washing machine in wardrobe DIY renovation for small bathroom with small budget
Add instructable to:
