3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Poster Magnet Board
Poster Magnet Board
We had a need for a magnet board design that was nice to look at, easy to build, and relatively inexpensive. Specifically, we needed it for our Disc Mounts which we created to store and display our CDs around the gaming zone. Learn more on our Disc Mount Project Page. We also used it for our 3D Super Mario Papercraft Magnet Board instructable so we could build, mix, and mash up scenes from the game.
This instructable shows you how to build a magnet board using a 24 x 36 in. plastic poster frame. These frames are inexpensive, fit common poster sizes, and single tin sheet usually can be purchased in this size. You can scale the design up or down for other sizes of frames as desired.
  • Buy super-strong, adhesive-backed, disc magnets for your poster magnet board projects.
Enjoy.
Step 1Get Parts and Materials
To build a poster magnet board you will need the following:
Parts and Materials
  • 1, poster frame with an acrylic face (24 x 36 in.)
  • 1, cool poster/picture (24 x 36 in.)
  • 1, flat sheet of galvanized tin (24 x 36 in., 24 - 30 gauge )
  • neodymium magnets (between 1 - 2 lbs pull force)
  • 1, roll masking tape (1" wide)
Tools
  • leather work gloves to handle tin
  • hot glue or white glue
  • tin snips (unneeded if tin is correct size)
  • tape measure (unneeded if tin is correct size)
  • straight edge (unneeded if tin is correct size)
  • marking pen (unneeded if tin is correct size)
  • hammer and block of wood (not pictured, unneeded if tin is correct size)
About The Frame: You want an acrylic face, not glass. Glass can break and is too smooth for these magnets to stick reliably. It should have a rigid backing. Hardboard or cardboard are typical. It should have tabs, staples, or a similar mechanism that bends to put pressure on the backing. The hanger should be attached to the backing, not the frame. Wood and metal frames are not necessary. We use inexpensive, plastic frames.
About The Tin Sheet: Magnets will not stick to aluminum, copper, brass, etc. The sheet can be smaller than the frame. 30 gauge sheet can usually be found at building supply stores in sections that carry heat , ventilation, and air conditioning ducting. Otherwise, suppliers of sheet metal in your industrial districts will usually cut you a piece to size. Bring your gloves to handle it.
Be aware that safety is your responsibility. Please read our Safety Warning and Disclaimer before you start.
26 comments
Apr 12, 2011. 10:42 AMaposters says:
Are you able to use movie posters from www.PosterRevolution.com?
May 30, 2010. 8:12 PMshirley xie says:
cool
Aug 27, 2008. 9:22 AMsonipitts says:
You may also be able to get tin sheets wherever there's a printing press. The offset process often uses tin plates to run their printing on. We used to get these all the time for crafts and stuff.
Aug 5, 2008. 9:10 AMemilyhanour says:
This is the best idea ever.
Aug 3, 2008. 9:53 PMadidame says:
Cool! I totally want to do this for my BF.
Jul 26, 2008. 12:56 PMthedownsmeister says:
first off, great job on the instructable, mate. Second, where did you get that poster, or does anyone know any cheap poster websites or stores?
Jul 29, 2008. 12:04 PMthedownsmeister says:
great, thank you very much!
Jul 28, 2008. 12:13 PMkannd86 says:
Great instructable!
Jul 24, 2008. 5:53 AMKiteman says:
Niggly point - where-ever you say "tin", I think you actually mean "steel" or "iron", since tin isn't magnetic.
Jul 24, 2008. 8:51 AMjosephprivott says:
It is possible to use tin in this project, even preferable if you live someplace humid (to inhibit rust). Otherwise you could use clear spray to coat the steel and achieve the same end.
Jul 24, 2008. 9:44 AMKiteman says:
Here we see the common error in understanding - the "tin" which magnets will stick to is not tin. It is tin-plated steel.
So-called tin cans are actually steel cans lined with a very thin layer of tin.
Tin itself is not magnetic - the magnet attracts the iron or steel through the tin.
Jul 24, 2008. 6:06 PMjosephprivott says:
There is no error in interpretation the word tin. I am using the word in its common understanding, not the specific, elemental description. Under this usage, it makes sense. You are correct though.
Jul 26, 2008. 7:30 PMmdeblasi1 says:
Is that really the "common understanding" of the word tin? I don't do much work with tin, but I have taken chemistry and knew it had it's own entry on the periodic table---Sn is not Fe. But my husband, an electrician, not a chemist, said, "sure magnets stick to tin." Still I KNEW that was just not possible. What's up with that?
Jul 27, 2008. 6:28 AMKiteman says:
It's the fault of "tin cans" - they're made of tinplate steel, but, people being lazy, they stopped listening after the first syllable...
Jul 26, 2008. 10:10 AMalex-sharetskiy says:
Wimpy wimpy wimpy, Hefty Hefty Hefty!
Jul 24, 2008. 4:24 PMfirehazard07 says:
Incredibly well illustrated project, I may have to try this. I wonder, would the paint that makes a chalkboard surface stick to the tin? Or maybe even a thin layer of plexiglas to turn it into a white boar. . . .
Jul 24, 2008. 8:35 PMninjamonkey says:
In the instructable you said that glass should be avoided because it is too smooth for the magnets to be reliable, is there any way to have this wonderful idea be a whiteboard and a magnet board that doesn't have magnets falling off? Thanks for this great instructable!
Jul 24, 2008. 7:58 PMinquisitive says:
Brilliant! I reused an old-fashioned "in-out" board from the office, but I love the simplicity and variations with this that the scene could be changed to anything desired. I will do this for my cubicle so I can position my benders on it! Thank you!
Jul 24, 2008. 12:11 PMzubbie2000 says:
don't the magnets affect the cd's?
Jul 24, 2008. 3:59 PMvanbo says:
Na, CDs are optical and not magnetic, so they should be fine.
Jul 24, 2008. 11:16 AMMatt4_16 says:
awesome idea though im gonna have to make something like this
Jul 23, 2008. 7:59 PMBrennn10 says:
This is such a great counterpart to your first instructable. Not only can you have your cd's in a convenient spot, they can look decorative too! I love it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:laboratory424(Laboratory 424)
