Step 1Get Parts and Materials
Parts and Materials
- 1, poster frame with an acrylic face (24 x 36 in.)
- 1, cool poster/picture (24 x 36 in.)
- 1, flat sheet of galvanized tin (24 x 36 in., 24 - 30 gauge )
- neodymium magnets (between 1 - 2 lbs pull force)
- 1, roll masking tape (1" wide)
- leather work gloves to handle tin
- hot glue or white glue
- tin snips (unneeded if tin is correct size)
- tape measure (unneeded if tin is correct size)
- straight edge (unneeded if tin is correct size)
- marking pen (unneeded if tin is correct size)
- hammer and block of wood (not pictured, unneeded if tin is correct size)
About The Tin Sheet: Magnets will not stick to aluminum, copper, brass, etc. The sheet can be smaller than the frame. 30 gauge sheet can usually be found at building supply stores in sections that carry heat , ventilation, and air conditioning ducting. Otherwise, suppliers of sheet metal in your industrial districts will usually cut you a piece to size. Bring your gloves to handle it.
Be aware that safety is your responsibility. Please read our Safety Warning and Disclaimer before you start.
comment
Add Comment
Add Comment
