Posting Sensor
Introduction: Posting Sensor
Lets get right into this. I was logging temperature of a room to an Excel sheet via Serial.print commands, then importing CSV files and yada yada. I couldn't get to the data unless I was at home, and also I had to leave my computer running in order to log the data. I needed a better way to log temperature (or anything for that matter) and be able to access it from anywhere.
Google Docs is a great free service that fits the bill perfect. There are tons of tutorials showing how to do this HOWEVER they are all out of date due to Google changing things up on their forms. So I am here to re-write everything I learned to help you get started and logging real time to the internet. You will need: Arduino R3 Ethernet shield (probably can be done with a YUN or WiFi, but I used Ethernet.) ** I added a screen shot of my dashboard which displays all the data that I am collecting. This is all based on 3 temperature sensors.**
Step 1: Get the Required Account
Get the required accounts:
1. Google. Get a google account. its 2016, you should probably have one by now. FREE
2. Get a pushingbox account via FREE and it uses you google account for user info.
Step 2: Create a Google Form and Get FORM KEY
  • Inside of google Drive you can create a 'Form' . For the sake of making this simple I will create a single question select the short answer response form as shown. When that is complete, click send form.
  • A screen will pop up which will have an option to show URL. Click that(shorten URL) then Copy the URL that is spits out.
  • Past that into your web browser and you will find yourself at the form you created.
  • From here you will need to right click and select 'Inspect Elements'. This will load the HTML code for the form. You are looking for the line of code that is defining the Text input box. You will find a section of the code that is "
    " (numbers are dependent on you)Take note of this. I will be referring to this as "FORM KEY"
Step 3: Pushingbox, Service and Scenarios
  • Head over to and login with the same google information that you created the form with.
  • Go go My Services and create a new custom service. You will need to go to your google form and submit a response. This will load the response page of your form. Copy this URL and past it into the pushingbox Service URL field. Name it whatever you want and set method to GET. Done.
  • Now go to my scenarios.
  • Just Give a name and ADD
This is where the FORM KEY will be used. Following my template, past this into the scenarios field to add:
Change the bold text with your FORM KEY that you gathered in step 2. Leave the ? and the other stuff, just replace the bold with your stuff. Now copy that whole string Click ADD ACTION and past into the DATA scenario field. Now click SUBMIT.
  • Then it will say nice job! or something positive like that. Then select the Service you created only moments ago. This will give you a DEVICE ID remember this, in fact. write it down or copy and past it into a note pad doc. This will be used in the arduino code. Congrats, you are done with that and now its time to code the arduino.
Past below format in your browser
Above will upload 12 to your google form
I have attached my very simple code to run this example. You will find a section of things to be edited. This code will send responses to the form you created in the form of data. You will see google then creates a spread sheet and logs all the responses WITH time stamps! Use this to create data logs of temperature, light levels, humidity, motion whatever you want!
The example attached uses a analog sensor.
Can easily be modified for something else.
I hope this lets you walk through the steps and get some data posed to the web. Thanks
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Hope all is well.
    This is Jim from WIZnet.
    As you might already know, WIZnet is well known for its hardwired TCP/IP chip and its W5100 being used in Arduino’s official Ethernet shield.
    We also partnered with ARM as mbed silicon partners, and plan to offer more platforms for makers.
    To help makers grow the open source hardware community, we are having an IoT design contest, titled ‘Curation is Creation.’
    Come up with any IoT project idea and take advantage of this contest since we’re offering our ARM mbed-enabled WIZwiki-W7500 platform & WizFi310 shield at sample pricing.
    To start, register your account at
    This contest will be held from May to August, with 16 prizes totaling $15,000.
    We expect and hope that many makers, including members of WIZnet Museum, will participate and share their knowledge.
    As this is a contest for the open source community, WIZnet wants to give back the power of the vote to all participants.
    Hence, you can vote and provide feedback of other projects from September to October.
    More details of the contest are available at and technical questions are answered at
    Hopefully, you’ll find interest in this contest and we look forward to your next creative IoT project!
    Best Regards,
