3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pot Stand-Windscreen
Every time I travel 'under my own power', I try to learn and become more efficient - which translates to 'carry less weight'. You can do this by taking less, doing without, combining functions and/or getting lighter weight gear. This saves energy so you can go farther, longer and/or faster.
In this day an age of lightweight backpacking, many hikers are turning to alcohol stoves because they are super-lightweight, inexpensive, simple to use, and alcohol can be shipped in bounce boxes along the the trail. Since most commercial backpacking stoves have an integral pot stand, someone who uses an alcohol stove needs to provide one. But the same criteria for choosing the alcohol stove in the first place must also apply to the pot stand-windscreen too.
Most manufactured pot stands and/or windscreens are designed to fit a variety of pots and stoves, making them versatile at the expense of stove efficiency. But most lightweight backpackers use one pot and one stove. Having a stand that elevates the pot to an optimum level above the stove, and a close fitting windscreen that provides adequate air flow while blocking wind and limiting heat loss, reduces cooking time and more importantly, reduces fuel consumption. This translates in less fuel weight to carry.
Step 1My requirements for a pot stand-windscreen
My requirements for a pot stand-windscreen are:
1) lightweight and inexpensive
2) sturdy, stable, and functional
3) sized correctly but collapsible
4) ease of construction
1-Lightweight and inexpensive: Aluminum roof flashing is cheap and readily available at most hardware stores. Aluminum angle is also available at larger hardware/lumber stores. I had thought of using galvanized flashing but decided that aluminum would still be strong enough, saving weight. Various designs had me bending the flashing to provide pot support but I decided against it because of the difficulty in cutting and bending correctly.
2-sturdy, stable and functional: The pot stand uses a very stable 3-point leg design. The aluminum angles provide superior strength while the flashing helps with alignment. There is enough clearance to allow for optimum air flow while also protecting the flame from the wind.
3-sized correctly but collapsible: I only wanted a 1/4 inch gap around the pot to keep heat loss at a minimum. But I also wanted the pot stand to collapse small enough to insert inside the the pot for transportation.
4-ease of construction: Several of my early concepts were one-piece designs that filled all the requirements except ease of construction because they utilized too many cuts and bends in the aluminum flashing. Using the aluminum angle increases the weight, but also increases strength and ease of construction, an acceptable alternative.
9 comments
Jan 14, 2012. 7:58 AMgwestlun says:
Finished making one, love your design, but I only had a gap of about 1/8 of an inch around the top and the flames heated the screen up to where it was actually melting it! Going to make another slightly bigger to see if that works. I am using a Trangia stove so if that one starts to melt I will have to go to a much lesser of a heat range stove. thanks for your ideas!
Aug 1, 2009. 4:17 PMfoothillfrontier says:
Holy flipping trail bologna! I love your design, including an integrated potstand with the windscreen is sweet. I also like how you vented the windscreen with the holes to adjust diameter of the screen. Simple is good. Life is Good
Feb 21, 2008. 3:19 PMLinuxH4x0r says:
Wow! great job! Very professional looking. How did you make the stove? +1
Feb 23, 2008. 4:48 PMLinuxH4x0r says:
Thanks, I'll look into it.
Feb 22, 2008. 10:16 AMchuckr44 says:
I love these simple, functional, light items. Well done, sir.
Feb 21, 2008. 5:06 PMxtank5 says:
The Hobo Life group is not worthy!!! *bows and backs away while doing it*
Feb 21, 2008. 3:01 PMGorillazMiko says:
My mom would definitely love this, but I don't think I can do it. But many people can do it, like you, so I have to say GREAT JOB on this Instructable.
Feb 21, 2008. 1:33 PMjohnnyshaman says:
I can't imagine a more perfect solution to the wind screen/pot holder problem. thanx for the Instructable
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wandering
