Introduction: Potable Diy Amp
Picture of Potable Diy Amp
This is my second instructable so far. Its a simple potable amplifier which uses the ever popular lm386 amp ic.
The construction is rather easy with few components and it sounds great. Its potability makes it more handy.
This can be used as a computer amp, guitar amp or even as a amp for your mobile phone.
So, here it goes..............................
Step 1: Materials Required
Picture of Materials Required
lm386 ic with stand
10k pot
10r resistor
0.1uf ceramic cap(30)
250uf/16v electrolytic  cap
10uf/16v electrolytic cap
protoboard
soldering equipment
9v battery with clip
enclosure(any)
Speaker
1/8in male jack
slide switch
wires(of course)
Step 2: The Schematic
Picture of The Schematic
This is a simple design, in this arrangement the amp gives a gain of 200.It is acting as a non-inverting amp giving audio output is about 2-3watts. The volume can be adjusted by the 10k pot. The gain can also be adjusted by adding a 10k pot in series with the10uf cap in between the 1 and 8 pin.
Step 3: Solder It Out
Picture of Solder It Out
Solder everything. You can use a 1/4inch jack for connecting the guitar.
Step 4: Put Everything in the Enclosure
Picture of Put Everything in the Enclosure
 You can take any plastic or wooden box you like for the amp. Here I have used a sweet container box. Make holes for wires and the pot and the speaker on the lid. Use double sided tape to stick the speaker into the box. After all the connections put everything inside the box and close it. Color the enclosure if you want as i did.
Step 5: Testing
Picture of Testing
Switch onn the amp connect the male jack into a mobile phone or mp3 player. If it does'nt work open the box and check the connections properly again
Step 6: Finish!
Picture of Finish!
Now you have a potable amplifier. Now enjoy music any where you want.
Hope you like it.
Feel free to comment.
joshr123 (author)2013-11-07
#7 should not have any connections.
About This Instructable
4,196views
50favorites
License:
Bio: Into electronic stuff!!
More by Ankan Nayak:Potable diy ampPotable 9v dark activated light
Add instructable to:
