Potato Battery Driven LED by craftknowitall
Featured
So, if you looked at my profile you would see that I like physics.  When the challenge for “Potatoes” I just knew that I need to do a project that highlighted the lowly “Potato Battery”.  So here is how to make a Potato Battery and have it light an LED light.
Step 1:
Supplies:
Potatoes
Galvanized nails
Shinny copper pennies
Wires with alligator clips on each end (2+ per battery)
LED bulb
Multi meter
Knife
Cutting board
Step 2:
A battery is a way to store electrical energy.  For a battery to work it needs to have 3 things, two electrodes (metals, one + and one -) and electrolytes (minerals).  The batteries we are going to make today uses the electrodes of copper (pennies, anodes, +) and zinc (galvanized nails, cathode, -) and the electrolyte of K (Potassium) that is found in potatoes.
Step 3:
Take a potato
Step 4:
and cut it in half. This will make 2 batteries.  Potatoes are juicy, which is part of the reason they can be made into batteries.
Step 5:
Take a knife and put a slit in the potato and slip the penny into the slit.  Push as much of the penny into the slit as possible, you want just a little bit sticking out of the potato.  Push the nail most of the way into the potato,(at this point I cut the nails in half, so that they weren't so tall).  Do not let the electrodes touch, keeping them about 1 inch apart.
Step 6:
Turn on the Multimeter and put it at the lowest voltage reading.  Make sure the red probe is in the + slot and the black probe is in the – slot.
Step 7:
Use the red line to touch the penny in the potato and the black line to touch the nail.  You can read how much voltage you have available in this potato battery.  It reads .85 volts, not bad but not enough to do anything fun.
Step 8:
To increase the voltage, you will need to create more potato batteries and wire them in a series (that means to connect the + electrode of one battery to the – electrode of the next battery).  So I created 3 more batteries from 3 more potato halves.
Step 9:
Then I used the alligator clips connected to wires and wired first 2 potatoes together,
Step 10:
this time the voltage read 1.69 volts.
Step 11:
Let's take a minute and look at the LED light.   It has one long leg and one shorter leg.  The longer leg is the anode (+)  and the shorter leg is the cathode (-).  I clipped the batteries to the LED light (+ to+ and - to-), no light, therefore, not enough voltage.
Step 12:
I wired all four batteries together in series, and found what the total voltage is of the 4 batteries was 2.38 volts and I again wired in the LED light, again no light.
Step 13:
Finally I wired six batteries in series and it had a 4.08 volt reading.
Step 14:
This time the light lit up!  Hurray!   Potatoes can be used as batteries.
Step 15:
Have fun playing with your new batteries, maybe you would like to experiment with increasing current by wiring the potato batteries in parallel as well as series.  Good luck and Enjoy!
picturelights1 says: May 6, 2013. 5:20 AM
A potato battery is a type of electrochemical cell. An electrochemical cell converts chemical energy into electrical energy. In the potato battery, there is a transfer of electrons between the zinc coating the galvanized nail that will be inserted into the potato and the copper wire that will be inserted another part of the potato.
craftknowitall (author) says: Dec 26, 2012. 8:16 AM
Yes it can. Look at this Instructable to learn more: http://www.instructables.com/id/Salt-Water-Powered-Paper-Lights/.  Thanks for commenting.
D5quar3 says: Dec 25, 2012. 6:25 PM
If the battery works on the electrolyte Potassium, is it possible to make this work with salt water? Would NaCl be electrolytic enough?
MakingWorld says: Jul 7, 2012. 8:32 PM
science comes from the life.
marklundquist says: Jun 1, 2012. 9:52 AM
Are your potatos rechargeable:)
scoochmaroo says: May 29, 2012. 5:58 PM
Woman, you never cease to amaze me!
craftknowitall (author) says: May 31, 2012. 8:16 AM
I keep coming back to this comment, it really tickles my fancy. :)
craftknowitall (author) says: May 29, 2012. 7:55 PM
When I first learned that the Challenge was potatoes, I knew that I will have to do something wild and wonderful, which meant, not my "potato soup or salad" recipes. Glad you like it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
