Potato Cannon Silencer
24,048
25
15
Posted in PlayOffbeat
Introduction: Potato Cannon Silencer
How to build this silencer.  works well in turning the loud crack that a potato cannon makes into a low" poomph". This silencer works by taking all the excess pressure behind the potato, and slowly releasing it before the potato cannon exits the barell.
Costs around 15$ to 20$
Step 1: Materials
Heres what i used. (this is based off of a 2" barrel diameter.)
-One 2" to 2" coupler.
-Two 2" to 4" coupler.
-A lot of cotton.
-A piece of 4 inch pvc (or abs) pipe.
-A piece of 2 inch pipe.
Step 2: Building It
Heres how i built it:
The first thing you need to do is take the ridge off of the 2" to 4" couplings. This stops it from sliding onto the pipe and needs to be removed with a dremel tool or sandpaper.
After that is done, put the 2" to 2" coupling onto the end of the 2" pipe. Slide the 2" to 4" coupling down the pipe untill it touches the 2" to 2' coupling. (do not use glue)
You should then decide how long you want the inner barrel to be. i made mine 14 inches long but you make want one larger or smaller depending on the size of the cannon.
After cutting, slide the 4" pipe onto the 2" to 4" coupler and determine where you want to cut the 4" pipe.
Step 3: Building Continued
The next step is drilling the holes. a 3/16" drill bit is a good size to use. you will want more holes on the inside than the outside. You can use the drill bit on both pipes and always start deilling less holes. try not to put too many holes (especially on the outside). For my silencer i spaced the holes on the outside pipe (4") about an inch apart. This may be kind of confusing but dont worry about messing it up, it is easy too fix if to little holes are drilled.
Step 4: Packing the Cotton
Assemble the silencer without the top 2 to 4" coupler. Fill with cotton without packing too tightly. Overfill a little bit so some cotton goes into the top coupler when you slide it back on.
Step 5: Final Assembly
Take the pars of the silencer you filled with cotton and put the top coupler on. You now have the finished silencer. I did not use pvc glue because the parts fit together tightly. If you want to use glue, do not glue it untill you have tested it and no that everything is working right.
Step 6: Shooting
Load your potato cannon like normal and then slide the silencer on. it should fit snugly but if not you could put a small ring of thin tape on the end to hold it on.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    15 Comments
    I made one with a barrel length of 14 inches and the outer barrel is 8 inches long and it is 1.5 inch barrel by 3 inch chamber. I filled it drilled a lot of holes with fewer on the outside like you said and i didn't have cotton balls so I used steel wool instead. i've tried it out and I can't tell really if it works. Is that a way to make it that would work?
    this thing is awesome :D from now on im gonna add this to all my spud guns so my neighbors dont keep freaking out when i show off to my friends.... :P
    agreed.
    gonna put this on new potato canon iv'e been dreaming of...
    breach loading...
    auto mode...
    mounted on snow tank..
    etc.
    Pardon my bad English use a translator. I am from Uruguay, I worked for me to make a pipe muffler with a 3 "diameter and 12" long.
    A single camera half is empty and half filled with center hole washers projectile size, and outside pipe size of 3 "inside .. the potato passes through hole washers .-
    The washers are separated by small pieces of pipe 1 "long to complete the other half. A washer is on top.
    the result is very good.
    greetings and good work. Juan Jose
    I think I'm going to try building this so the cops won't show up next time and take the potato cannon away. :(
    I would also reccomend not gluing the parts together but using duct tape or some kind of temporary way to hold them together. After about 500 shots or so my cotton went bad and i had to repack it.
    I recommend other people who are planning making this, not to compress the cotton inside too much otherwise air wont exit before the projectile comes out. 2nd Make a lot of small holes on the smaller tube and large holes on the larger tube. This is is a photo of a real gun suppressor. But this design still works.
    I'm so sorry my grandfather teach me how to make a real gun silencer and this is a wrong design. But it may still silence a gun but has a low reduction in sound :))
    You're correct. This design would not work as well on a real gun but I find it to work great for a potato cannon. Potato cannons have slower projectiles and more gas to be released so the design is altered.
    Yup your right. BUt making this silencer longer will reduce a lot of sound. Anyway I voted this a 5 STAR
    Yea thanks for the rating. as for my cannon I definitely would see more sound reduction if I would have made it longer. It all depends on the size of the potato cannon.
    it would be better to add a socket to thred (threads on outside) to the silencer then add a socket to thread (threads on inside) to the barrel so you can screw it in or unscrew it.
    yea that would work too. i was just going for simplicity.
     Hmmm, screw on one would be quite amazing. Also opens up to other addons (flashlight, laser, larger pojectile etc.)
