Potentiometer Trigger 3d Printed Stackable
4,201
68
Published
Introduction: Potentiometer Trigger 3d Printed Stackable
I needed some triggers for testing my inmoov hand.
this was my first test design.
Material needed:
  • 5k potmeter B5k
http://www.ebay.com/itm/191674495842?_trksid=p2057...
Step 1: 3D Print
Print STL files.
I printed them at this settings:
z=0,2
infill=25%
No brim, supports or raft
http://www.thingiverse.com/thing:1681562
Step 2: Potentiometer
cut off the knurled part.
There should be 2mm left
Step 3: Dryfit
Dryfit your parts.
Set your potmeter at center position (the knob)
Make sure you fit the potmeter on the right side of the trigger
Step 4: Glue and Screw
Glue the trigger from underside, make sure you dont get any glue in the moving parts of the potmeter.
glue the spring at the designated flat place.
You may stretch or cut the spring to fit it at best.
Screw in your set screw to fasten the potmeter.
Step 5: Soldering
solder the pins, and stretch the cable through the hole.
Step 6: Arduino Setup
5v
Ground
A0 ; analog 0 port
calibrate by tweeking the highlithed numbers
val = map(val, 0, 1023, -785, 785);
First number is start position, and second is triggered position
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    Great component for robotics - especially for the emerging Fully-3D-Printable robots.
    nice design!
    Nice. This design could be really useful for a lot of robotics projects.
