Introduction: Pov Spinner
So i was thinking: let's make something obvious.
This instructable is on making a spinner with a persistence of vision illusion inside.
Step 1: Parts and Wiring
- ATtiny 45 ic
- 5 smd led (1206)
- 5 smd resistor (47 Ohm)
- 2 small pieces of pcb
- 1 coin battery (3v - 16mm)
- 8 pieces of metal (for balance)
- a piece of mdf (3mm) for the spinner itself
- a 22mm metal ball-bearing (center)
The wiring is pretty straight forward. I followed the datasheet from Atmel (see screenshot above)
- The positive pins on the led go to PB0 - PB4 on the ic. I added a resistor in between.
- negative pins go to GND.
- Power the ic by connecting the battery to VCC and GND.
Step 2: Programming the Ic
In order to put code on the Attiny we need to follow a few steps:
- Upload the 'ArduinoISP' example to the Arduino board ( located in the examples folder)
- In Arduino preferences point to https://raw.githubusercontent.com/damellis/attiny... or look for attiny library (by David A. Mellis) and install it
- In Tools> programmer select the ‘Arduino as ISP’ option
- Attiny 45 runs on 1 Mhz but can be changed under ’Tools’. That's a bit to slow for persistence of vision: change it to 16 Mhz (normal clock on a regular Arduino)
- If you do the previous step you have to burn the boot loader. (Tools > burn bootloader)
- wire the Attiny to the Arduino board (see this page for the exact wiring or look at screenshot above). You also need a 10 uF capacitor between reset and ground to avoid reset (and starting the bootloader)
- upload the code below to the attiny.
- done.
arduino / attiny code from the spinner:
<p>int letterSpace;<br>int dotTime;</p>byte invader[] = {1, 1, 1, 0, 0, 0, 0, 1, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 0, 1, 1, 1, 0, 0};
byte invader2[] = {0, 0, 1, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 0, 0, 1, 1, 0, 1, 0, 0, 1, 0, 0, 0, 0, 1, 1, 1};
int amount = 12;
void setup()
// setting the ports of the leds to OUTPUT
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
letterSpace = 2;
dotTime = 1;<br>}<br>void printImage(byte pix[]){
int y, i;
// image
for (i = 0; i < amount; i++) {
for (y = 0; y < 5; y++) {
digitalWrite(y, pix[y + (i * 5)]);
delay(dotTime);
// space between images
digitalWrite(y, 0);
delay(letterSpace);
}void loop(){
printImage(invader);
printImage(invader2);
}Attachments
Step 3: Simple Spinner Images
create images
The spinner needs an image to display so i've made a small browser page to create sequences / images for the spinner. (attached as file)
It has an interface of multiple input tags (type: checkbox) and two functions: one to create a new column and one to create the sequence of 0 and 1.
My son (6) had a good time making some invader like sequences.
js:
var start = 8; // start with 8 columns
// a function to create a column of inputs. i have 5 led in the spinner..
function makeColumn() {
var box = document.createElement("div");
box.id = "col"; // check css for styling.
for (var i = 0; i < 5; i++) {
var input = document.createElement("input");
input.type = "checkbox";
box.appendChild(input);
document.body.appendChild(box);
}// function attached to load event. Creates the buttons and the columns based on the amount stored in start variable
function create() {
var b = document.createElement("button");
b.innerHTML = "create";
b.addEventListener('click', generate);
document.body.appendChild(b);
var b2 = document.createElement("button");
b2.innerHTML = "add row";
b2.addEventListener('click', addNew); // event for adding a new column
document.body.appendChild(b2);
var input = document.createElement("p");
input.id = "result";
document.body.appendChild(input);
for (var i = 0; i < start; i++) {
makeColumn();
}// adds a new column
function addNew() {
makeColumn();
start++;
}// function to generate the sequence of 0 and 1
function generate() {
var inputs = document.querySelectorAll("input");
var result = [];
for (var i = 0; i < inputs.length; i++) {
var r = inputs[i].checked ? 1 : 0;
result.push(r);
var pusher = document.querySelector("#result");
pusher.innerHTML = result;
// start everything when page is loaded.
window.addEventListener('DOMContentLoaded', create);css:
#col {
display: inline-block;
}input {
display: block;
-webkit-appearance: none;
width: 20px;
height: 20px;
background: black;
margin: 1px 1px 0;
}input:checked {
background: yellow;
}The spinner itself was made with NodeBox 3 - an interesting tool for design. The svg output is included.
