3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Prepping a Bike Frame for Powder Coating with Logos
I was given a nice Specialized Allez frame that just happened to be the right size for a girl that I am somewhat fond of (in the spirit of understatement). The frame was damaged and I did not really care for the stock Specialized aesthetic, so I stripped the paint off, added some logos and had the frame powder coated anew. The process is toxic but straightforward, and the results are not bad....
Step 1Strip the Paint
Strip the Paint
There is not much finesse in this step, but there are a couple of tips. The first tip is that most places that powder coat things will also strip them for you. I was quoted $65 for the job of stripping the paint off of my frame. Naturally, I am far too stubborn (stupid) to recognize the value of this and opted to do the stripping myself.
Ok, so for the actual tips:
1) Get the Red Jasco - the really nasty stuff
2) Use _Neoprene_ gloves - Jasco will eat through everything else
3) Have a lot of scotch-brite on hand to aid in the stripping
4) A set of jewelers' files also help get to the bits stuck in the welds ... but will do bad things to the files.
The process of stripping the paint took me about 10 applications in various places. You wipe the Jasco on, let it sit and then rub the paint off. It is gnarly - do this outside.
52 comments
1-40 of 52next »
Oct 26, 2011. 11:21 PMdhardacre says:
Do you know what the powder coaters put on the logo to prevent the powder from sticking to it? So they can just wipe it off?
Jun 4, 2009. 6:03 AMhybridracers says:
this is more kind of a diy of how to have everyone else do the project. I fortunately have access to most of the tools but the average person does not. Also the title has nothing to do with what happened.
Jun 4, 2009. 10:36 AMHandsy says:
= most confusing comment evaaar
We powder coated a frame: CHECK
The frame had logos: CHECK
I think the essence of this instructable has been well documented via the title.
Jun 4, 2009. 11:41 AMhybridracers says:
No.......the problem with this instructable is that the only thing most readers can do is paint strip the bike. For it to be a true one it would have shown a DIY setup for powdercoating, logo making (and Id let that one slide) and the such. The only thing this showed most people is how to have someone else do a lot of work for you to make a cool bike.
Jun 4, 2009. 12:09 PMtoekneebullard says:
I gotta agree with hybrid racers. This is how to PREP a bike for powdercoating, not how to powdercoat.
Mar 11, 2011. 2:16 AMeddy3305 says:
knitpickers! I am an old far#$ and have been around and can and do build almost anything out of junk and make it look like it is bought new. My job is to fix what proffessionals cannot. I scanned this months ago and spent three days to finally track it down again so I could steal your idea to use. I say its brilliant and clever and I don't care what you call it.
eddy3305
Jun 4, 2009. 1:55 PMCalorie says:
splitting hairs, legalese...who cares. He did a rocking job. It's a great idea, and one that I will use for my next beau. Everyone here uses the work of someone else. I have yet to see someone synthesis, distill and use their own chemicals (minus the catnip guy.) What about the fabric we use, or the LEDs we work with. He left the heavy lifting to someone else. Kudos
Jun 4, 2009. 2:26 PMtoekneebullard says:
Obviously we all use other people's work. But it's one thing to use an LED in your instructable, and another to title it "how to build an LED" when you just use one in your 'ible. Corwin, I don't mean to hound you or anything, but truth is I clicked on your instructable because I was interested to learn if I could feasibly do powder coating DIY. (I truly know nothing of the process) So to read through the whole thing and then see at the end you just passed it off to someone else (perfectly respectable if you're not saying 'here's how to do powder coating' ) was pretty disappointing. None the less, the logo attachment was certainly interesting, and I'm sure useful to many people. Thanks for contributing, and I hope you don't take anything I've said as anything more than a little constructive criticism on naming your instructables.
Jun 11, 2009. 6:50 AMCalorie says:
Less talky and more searchy....
http://www.eastwood.com/hotcoat-powder-coating.html
And yes, you are hounding the poor guy/girl. It would of been cool to see the process from start to finish. The link I provided shows what it takes to actually powdercoat at home at a realistic cost. It is 'cost prohibitive' as we might say in economics.
You'd get an approximately durable finish if you took your time and carefully used high quality spray paint (yes, from a can). I've seen it done and it is amazing. Powder coating costs a lot for diminishing returns, unless you really want powder coating.
Jun 11, 2009. 12:26 PMhybridracers says:
I know where to get supplies........Like I said, the title insinuated that he was doing this diy, you arent helping anything. He obviously has access to a machine shop to make contour presses and other goodies........which is cool......those are non common things. I have a powdercoat booth set up I made myself........I opened this page to see if anyone had something that worked better.
Jun 11, 2009. 3:55 PMCalorie says:
That's true. Sorry for the smart alecky remark. It just seems a bit picky and for whatever reason I perceived that s/he needed defending.
It is demoralizing for one to write an instructable and then to be bashed about. I think it is safe to say that we all want to encourage additional i'bles. A newbie might find it additionally intimidating after running across a situation like this.
I've wanted to write one, but I'm a bit intimidated by the level of detail. How much detail is good enough? I've repaired my plastic tanks on my radiator. I don't show "how" I removed the radiator (there are many car models, and the process varies greatly) but instead focus on out of car cleaning and prep. And I know that someone will inevitably say that I should describe how I removed the radiator. It's all a bit frustrating.
And I have found that passions run deep with bicycles. Whether it be WD-40 as a lubricant (some think using it will make your bike burst into flames) or if helmets actually work (they do, if they didn't the litigious nature of our society would either run the companies out of business or encourage refinement until they worked.) Cyclist are unusual by nature, and I count myself among their kind.
I'm off to powder coat my cat. Peace Out!
Jun 4, 2009. 7:33 AMnick222 says:
"Powder Coat a Bike Frame with Logos" as a title makes me think that this would be a 'how to' powder coat your bike frame instead of just taking it to a shop... I think the textured logos part is awesome though, very creative!
Jan 23, 2010. 5:26 AMDavidnipp says:
 Using a nitrile glove is the best protection the general public can get their hands on (excuse pun) for a moderate price.
Aug 17, 2009. 6:11 PMmarple200 says:
I like this. I can see how this approach can be applied to numerous projects. Cutting thin aluminum and working with jewelers tools is within anyone's capability.
Jun 4, 2009. 6:17 AMchrwei says:
there was paint on the logo's? did you skip a step?
Jun 8, 2009. 2:22 PMjswilson64 says:
No paint on the logos, he had a dude at the powder-coater place wipe it off before they baked it.
Jun 4, 2009. 3:18 PMTagarashi says:
wow take the frame to a powder coater? I would have never thought of that!
Jun 4, 2009. 4:29 PMcamp6ell says:
(removed by author or community request)
Jun 7, 2009. 12:24 AMcamb00 says:
PREPPING a frame for powder coat not misleading at all
Jun 6, 2009. 8:56 PMeatin ramen says:
good step by step on how to avoid paying the pros to do the stuff you can do yourself. but if you want your frame to look that good, you have to let the pros do the finishing touches. good work
Jun 6, 2009. 9:02 AMgopackers says:
I think it's beautiful! I wouldn't want to diy such a large, expensive part at home anyway. There are people on the cnczone that would be happy to cut logos for you at a reasonable price. I was wondering, while reading the instructable, how you finished the logos and when you said they wiped the powder off I thought how simple that was. Good job, I love it. If I ever see it I might steal it. (just kidding)
Jun 4, 2009. 8:36 AMelectrotyler says:
Is there a reason that you would not want to bead blast an aluminum frame? I would think that this would be the quickest, easiest, cheapest, and least toxic route for paint removal, so I wonder if there's a catch... Soda blasting might also work.
Jun 4, 2009. 3:15 PMTagarashi says:
no blast beader or blast enclosure?
Jun 5, 2009. 10:40 AMelectrotyler says:
That's a pretty good reason, but most powder coaters that I've spoken with can either bead blast items in-house, or know where to send them for blasting. I've had a couple of steel bike frames powdercoated, and this has produced good results quickly and at low cost.
Jun 3, 2009. 8:41 AMpyrocop1 says:
What did it cost to powder coat the frame?
Jun 4, 2009. 7:38 AMPkranger88 says:
That seems high for a part that size. Did you have to have it media blasted first? The shop I go to does a top notch job and that frame would've cost less than $30 to coat, but it could be that much if it needed blasting. Not trying to burst your bubble, just hoping to save ya from getting ripped.
Jun 4, 2009. 12:27 PMzerol8on says:
where's that shop? i'm looking to powdercoat but bay area prices seem to be ~$100 ish...
Jun 4, 2009. 5:08 PMPkranger88 says:
Well, I live in Wichita, KS. The company I use is called Bob Eisel Powder-Coating. They do production fencing, aircraft, construction equipment, etc. Anytime I build a custom gate, machine auto parts, TV mounts, etc, they do a great job.
Jun 4, 2009. 2:33 PMbillygetsthegoat says:
how not to powdercoat a bike frame! did he get the girl? probably not or he would be out riding with her and not doing this! some of you folks need to get out and about a bit and away from your computers! so you know someone at specialised giving away reject frames -good for you! shame about the instructable though. love and luck to all. billy.
Jun 4, 2009. 11:08 AMreinovator says:
You can add metal filings to the 'JB weld' and it will conduct and adhere. Also it's a static charge which holds the power to the surface not just an electrical charge the key is melting point of the glue. but this is just my experience others may differ.
Jun 4, 2009. 6:30 AMskrubol says:
The biggest issue I've heard with JB Weld for using with powder coat is that it's not very electrically conductive. I guess not a problem when using it as an adhesive (you did it,) but as a filler I've heard the powder won't stick to it.
Jun 4, 2009. 10:29 AMHandsy says:
Since JB contains steel powder, I think it worked itself out. Nice instructable!
Jun 4, 2009. 7:34 AMPkranger88 says:
Any time you apply a non-electrically conductive material prior to powder coating you have to spray or apply a conductive paint to prep the surface.
http://www.caswellplating.com/kits/silvaspray.html
It can be expensive if you're only doing it once, but powder shops should have the spray
Jun 4, 2009. 9:16 AMhstan3 says:
Nice job! One caution though... The high temps (400 deg F for an hour usually) *may* compromise structural integrity in annealed aluminum. Probably not a factor in MB frames as much as a good road bike aluminum frame.
I just redid a Cannondale road bike frame and debated powder coating. Powder coating was actually a tad cheaper than painting at the same shop, but I went for the paint because the road frame is very thin annealed T6061 aluminum. They did an amazing job, and I'm happy with the result.
Your logo is quite awsome!
Jun 4, 2009. 9:09 AMskipwkk says:
What did the actual powder coating cost ?
Jun 4, 2009. 7:45 AMPkranger88 says:
I think this is a sweet project. When my MB frame's coating starts to die I may try something like this. A few thoughts though for next time. Could you have used solder or a silver epoxy to ensure conductivity? Another approach would have been to apply a non-conductive paint, paste, etc to the letters after they were applied so that the powder wouldn't stick. Also, your process of making the logos would make a great instructable. It looks like you have access to some nice equipment, so I'm guessing you either work in a machine shop or are going to school and have access to a shop there. Good job.
Jun 4, 2009. 7:42 AMrobhybrid says:
You could use a jewler's saw for this. It's a little tricky to get the hang of, but you can get some good results with a lot less investment.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:corwin
182x62x24cm - 308 kg/m^3
