Step 2Powder Coat
Preheat the oven to 450 degrees F (or the temperature appropriate for the powder you are using).
Powder coat the Candleholder Tops
Hang the assembled Tops using steel wire from an oven rack. A good place to attach is to the threads between two fittings. You can fit about eight of these at a time, or just two if you're making a single candleholder. Test fit the parts in the oven before you start up the powder to make sure they don't bump against the walls, heating element, or each other.
If you're using a toaster oven, insert high temperature silicone plugs into the elbows to support the part on a baking tray.
Clamp the oven rack between two supports - I used a ladder and a board. Attach the ground clip to any metal part of the oven rack. Now plug in the powder gun, fire up the air compressor and apply the powder.
You want a good dust cloud evenly dispersed around the part. Concentrate on the most deeply recessed inside corners first, and carefully move the gun around the parts to get an even coat. Remember, the electric charge is on your side, it will pull the dust toward the part and make it stick.
comments
Add Comment
Add Comment
