Power Antenna Hack
Introduction: Power Antenna Hack
Hello! friends
Welcome to my 2k16 DIY "Power Antenna Hack" project. In this project i'm gonna show you how to make your own power antenna at home with the help of this you can easily boost your internet devices signals like wingle etc. It's really easy to build.
So, let's get started.
Step 1: Material
You'll need
Cotton Buds (empty box)
Antenna with connector
Aluminium foil
Vernier Caliper, scale or any other measuring tool
Hot glue
Step 2: Size Measuring
Take a vernier caliper and measure a anteena's size from the bottom as you can see that in a pic.
Step 3: Making Hole
I just make a rough hole according to the size of antenna but you can do it better.
Step 4: Aluminium Foil Fitting in a Box
Now cut the aluminium foil according to the inner size of the box and then paste that foil into the box with the help of UHU like i do.
Step 5: Antenna Fixing
Now take an antenna and pass it through a hole and make sure just left the 3 inches from bottom where it bend from because sometime you'll need to change the direction of it. Put some hot glue at the end of the box (according to the pictrues). It's look like this.
Step 6: Installing a Connector
Now connect a connector with anteena.
Step 7: Finish
Now your power antenna is ready to use.
I hope you guys like it.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Hey, sorry, what is this antenna for? Broadcasting FM? receiving Wifi? something else?
    its for a walkey talkey
    By adding a reflector in a wrong axis you're screwing up antenna SWR without any gain. It's not a signal booster. I'd say it's antenna shield.
    Check this design - https://www.instructables.com/id/DIY-WIFI-Antenna-Reception-Booster
    I had the same thought. The base antenna emits and receives signals broadside to the length, like a donut with the antenna through the hole. But the reflector better fits an antenna with the opposite pattern.
    Okay i'll try to do better guys thanks for suggestions.
    I mean, axis of reflector is ok, but it has to be a parabolic reflector not a "wrap" around antenna...
    What are your measures? How much does it boost? Which frequency/type of wireless? Where does the additional transmission power come from?
    Ditto! Pretty please.
