Power Booster Circuit 48W to ~600W
1,399
Posted
Introduction: Power Booster Circuit 48W to ~600W
This instructable is for understanding and making a power booster circuit in which (unlike a voltage step-up circuit where voltage is boosted at the cost of current and a current step-up circuit where current is boosted at the cost of voltage) both voltage and current are stepped up at the same time at the cost of "time of operation (u will understand this after watching the video)".
Step 1: Inverter Circuit
You can make a simple CFL inverter circuit or you can buy an inverter 10W to 50W.They are really cheap.The good thing about CFL inverters is they accept I/P voltage from 3V to 15V unlike other controlled inverters which accept only 11V to 14.8V.
Please study the full circuit diagram :)
Step 2: Bridge Rectifier
You can use any AC to DC bridge rectifier.This rectifier will be connected to the O/P terminal of the inverter so that the O/P of the inverter becomes stepped-up DC.
Step 3: Capacitor Bank
You will need a capacitor bank.I used three 250V 10,000uF capacitors connected in parallel and this entire set is connected to the O/P of the rectifier.
You can increase the number of capacitors or you can also use a single 250V 10000uF capacitor but then the Pmax will be available for a shorter period of time.It is better to have higher capacitance for longer power operation span.
Step 4: Sockets
The socket will be connected to the TERMINALs of any capacitor since all are connected in parallel.The load will be connected to this socket.
Step 5: Load
The appliances that can be connected to the O/P socket have to be DC or universal (both AC or DC operatable).Don't connect AC fans or other AC operating devices to the socket.The circuit will damage it.You can use most hard-ware tools since they usually work on universal motors.
Step 6: DC Source
You can use any DC source from 3V to 12V.Lead acid battery or lithium ion battery.It will work. :)
After connecting the DC source, just connect the appliance to the socket and start using it.
Your booster circuit has successfully completed. :) :)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
7 Comments
Please what is the energy type the inverter is outputting?
Can i connect TV or Laptop to the circuit with more battery bank
Instead of rectifying the inverter output, why not connect AC capacitor(s) bank(parallel) to the output?
So your instructable doesn't show any circuit diagram.
You claim to be able to increase Voltage AND Current thus increasing the power output of the battery pack to some practically usable level..
HOW?
Were this possible you could drive a 240 volt motor and a 12 volt generator and recharge the battery pack.
i have uploaded the circuit diagram now :) :)
Yeah it is possible.... i believe you are talking about the cyclic energy...
Ok then... i will make and edit the instructable for better understanding.Thanks for pointing it out....
