Step 5Attach Leads to the Control Pad Board
Identify each of the relevant traces on the board. There is a common ground and one each for Up, Down, Left, Right, B, A, Start, and Select -- 9 traces total. For each trace, use the Dremel to drill a small hole next to the trace, near the edge of the board. Ideally the holes should just touch the edge of each trace. Use a razor blade to etch off some of each trace's protective coating near the holes, exposing the copper trace. Finally, insert a wire through each hole and solder it to the exposed trace.
I suggest using the aforementioned ribbon cables for these connections -- one ribbon cable for each half of the board, and the common ground as a single wire by itself. Leave the cables long for now, you can shorten them later once you have an idea of how everything will fit together.
Add Comment
