3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Power Glove 20th Anniversary Edition
Step 6Insert and Connect the Accelerometer
Place the accelerometer in the palm housing, orienting it so that its axes align roughly with the direction of the fingers. I placed it with X right, Y forward, and Z down, though these can be re-oriented in software later.
I suggest Dremeling a single hole in the unused area of the breakout board, so you can insert a screw through it. Use the screw holes in the original palm board to find the proper sized bit. Otherwise, you can use double-sided adhesive foam after you solder the leads to the board.
Solder the VCC, ground, and 3 axes of the accelerometer to 5 of the wires in the main bundle that connects the palm housing to the wrist housing. I used the following colors:
Red - VCC
Black - GND
Yellow - X
Green - Y
Dark Blue - Z
If you use adhesive foam to secure the boards, DO NOT attach it yet! We still have two wires to solder to this board.
1 comment
Apr 7, 2009. 7:53 PMCShaffer212 says:
I didn't have an accelerometer handy, but it looks like a great idea! Currently I can only track the hand motion with a Wiimote strapped to my arm. I might also try placing the Wiimote over my monitor and putting an IR light on the glove...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:biphenyl
I have a B.S. in Mathematics. I currently work for Flashbang Studios, an independent video game developer in Tempe. I'm an operative in Operation Mindfuck.
