Power Inductor Measurement Without LRC Meter
Published
Introduction: Power Inductor Measurement Without LRC Meter
About: Electronic enthusiast since 17. Working as a factory maintenance worker. Looking for a way to go to the university. Have a Higher Diploma in Electrical Engineering with average result, I regret for it.
This method is suitable for measuring high power, low bandwidth inductors, not suitable for small signal inductors.
This method involve the use of dangerous voltage, so please be CAREFUL of electrical safety.
Explanation
This method make use of household power line to provide a AC source of the circuit. By compare a circuit's impedance with and without the inductor-under-test, you can find the extra reactance generated by the inductor, therefore calculate its inductance.
Procedure
1.Gather information
1-1 Measure power line frequency by digital multimeter with frequency measure function
If your multimeter don't have this function, assume it is 50.0/60.0Hz (depends on region you live), doing so will create some error but are generally within acceptable range
1-2 Measure internal resistance of the inductor-under-test
Gathered information will affect the test result
2.Prepare material
3.Wire up the test circuit
4.Taking data: switch the circuit on, then measure AC voltage and current in the secondary winding of transformer
Do this quick(e.g. <=10 sec),or the heating of the resistor will create error to the measurement
5.Calculate inductance
with equations shown in above picture
Step 1: Instruments and Materials Required
Instrument:
1.Digital Multimeter
2.Clamp meter
3.Paper and pen
4.Scientific calculator(real one or online)
Material:
1.AC power cord with fused plug(0.5-3A recommended for 220v)
2.A AC switch
3.wiring terminal >=6(more the better)
4.some 400v rated wire
5.220v(or 110v)-12v transformer, power >=12 VA to provide enough current
6.27ohm 10W cement wire-wound resistor x1
Step 2: Example
Step 3: Afterwords
It is my first instructable, I apologize for any inaccuracy of content within.
This method is useful when there are no LRC meter available in your hands(they are too expensive, while you may not have a lot of opportunity working with inductor coils).
Using better multimeter and clamp meter can certainly improve accuracy of this test, the clamp meter I use here is just a cheap Chinese product.
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    8 Comments
    Not at all a good idea to use mains, especially if they are 220 V. Maybe get hold of a transformer and lower the voltage to 12 V...
    A Wheatstone bridge is safer I think !
    Very approximate.
    Your answer depends on the difference between two very similar values
    The inductive impedance is too low for this method to work well.
    You need to use a much higher frequency and/or a much higher inductance.
    I suggest the voltage loss across the inductor be similar to the voltage loss across the reference resistor.
    That would give you some chance of being nearly accurate to two significant figures.
    As is, your inductor measured value is not even accurate to 1 significant figure.
    Also with the minimum inductance range too.
    It is practical to raise the source frequency and lower
    the value of reference resistor(You reminded me to give it a right name)
    But with a price of more complex signal generating circuitry.
    IMHO, If you want to fast estimate the value of inductor,this method has its
    worth.
    Simplicity and precision are two things that always in contrary.
    his arithmetic is riddled with mistakes. Can't you see that?
