Step 1What you need
R1: approximately 100k-ohm resistor (such as: Yageo CFR-25JB series)
R3: current set resistor - see below
Q1: small NPN transistor (such as: Fairchild 2N5088BU)
Q2: large N-channel FET (such as: Fairchild FQP50N06L)
LED: power LED (such as: Luxeon 1-watt white star LXHL-MWEC)
Other parts:
power source: I used an old "wall wart" transformer, or you could use batteries. to power a single LED anything between 4 and 6 volts with enough current will be fine. that's why this circuit is convenient! you can use a wide variety of power sources and it will always light up exactly the same.
heat sinks: here i'm building a simple light with no heatsink at all. that limits us to about 200mA LED current. for more current you need to put the LED and Q2 on a heatsink (see my notes in other power-led instructables i've done).
prototyping-boards: i didn't use a proto-board initially, but i built a second one after on a proto-board, there's some photos of that at the end if you want to use a proto-board.
selecting R3:
The circuit is a constant-current source, the value of R3 sets the current.
Calculations:
- LED current is set by R3, it is approximately equal to: 0.5 / R3
- R3 power: the power dissipated by the resistor is approximately: 0.25 / R3
I set the LED current to 225mA by using R3 of 2.2 ohms. R3 power is 0.1 watt, so a standard 1/4 watt resistor is fine.
where to get the parts:
all the parts except the LED's are available from http://www.digikey.com, you can search for the part numbers given. the LED's are from Future electronics, their pricing ($3 per LED) is far better than anyone else currently.
Now I'm just trying to figure out how to modify the circuit. If the voltage is constant at 6v then you multiply by .5 of R3 for your current but I don't know what to do if using a different voltage.
so instead of the transistor you reccomended i used
http://www.mouser.com/Search/ProductDetail.aspx?R=BC184L_D27Zvirtualkey51210000virtualkey512-BC184L_D27Z
i put it together like in your instructions but nothing happens when i hook it up, does the collector current matter? im thinking that maybe somehow i might need a different R1? i used the same fet and used a .75 ohm current set and 100k ohm R1, 12v power supply and 1 cree xr-e, i also tried it with 3 batteries for 4.5ish volts, neither did anything.
thanks
The higher the Watts (wattage), the bigger the physical size of the resistor (it also gets more expensive). It therefore makes sense to select the resistor with the lowest wattage that can do the job safely, based on your calculations of currents and voltages. (I wanted to upload an image, but unfortunately the page does not seem to display uploaded images though it offers the option.) Your circuit will also be compact in size without getting unnecessarily bulky. For example, you wouldn’t need a 1 Watt resistor for a penlight LED circuit, though you could certainly use it.
If you apply a voltage across the resistor, there will be current flowing through that resistor. That current can be modeled by i = v/r (from ohm's law)
The power rating on resistors is the maximum allowed power that can go through that resistor. Power is the product of voltage AND current (p = v*i)
A standard "1/4" watt resistor can take up to 0.25 watts, which is really the most common type of resistor you can buy at hobby shops like radioshack. You can calculate power through a resistor using a handful of equations, all going back to p=vi and i=v/r
if you replace i in p=vi, you get p=v*v/r = (v2)/r - where v = voltage ACROSS the resistor and R is the resistance in ohms.
Hope this helps!
it should say power = voltage square divided by resistance
I'm new here and don't know much but project is a line of site of optical link in a short range, and I'm using white Lxeon 3 star. For the 1st part, is the curcuit parts going to change if i used LHXL-LW3C instead of Luxeon 1-watt white star LXHL-MWEC??????
i hope someone can help
thanks
Try this one...
http://www.reuk.co.uk/LED-Dimmer-Circuit.htm
(This circuit does not provide constant current)
The only question I have about this is the spec on the PNP transistor and gate resistor, and how one would connect a PWM circuit such as the one I've mentioned to the constant current source in this thread
3.5V x 1.4A = 4.9W
Are you actually putting 1.4A through your LED? That can't be a 1W LED, it must be a 5W. Reading the Digi-key page I think it is a 5W LED.
The LM317 puts out 5V? If so, you should need a 1.2 ohm 3W capable resistor, according to http://led.linear1.org/1led.wiz
Your 1 W LEDs should only require about 0.29 A or 290 mA @ 3.5 V
