Step 2Specs & Function
Specifications:
input voltage: 2V to 18V
output voltage: up to 0.5V less than the input voltage (0.5V dropout)
current: 20 amps + with a large heatsink
Maximum limits:
the only real limit to the current source is Q2, and the power source used. Q2 acts as a variable resistor, stepping down the voltage from the power supply to match the need of the LED's. so Q2 will need a heatsink if there is a high LED current or if the power source voltage is a lot higher than the LED string voltage. with a large heatsink, this circuit can handle a LOT of power.
The Q2 transistor specified will work up to about 18V power supply. If you want more, look at my Instructable on LED circuits to see how the circuit needs to change.
With no heat sinks at all, Q2 can only dissipate about 1/2 watt before getting really hot - that's enough for a 200mA current with up to 3-volt difference between power supply and LED.
Circuit function:
- Q2 is used as a variable resistor. Q2 starts out turned on by R1.
- Q1 is used as an over-current sensing switch, and R3 is the "sense resistor" or "set resistor" that triggers Q1 when too much current is flowing.
- The main current flow is through the LED's, through Q2, and through R3. When too much current flows through R3, Q1 will start to turn on, which starts turning off Q2. Turning off Q2 reduces the current through the LED's and R3. So we've created a "feedback loop", which continuously tracks the current and keeps it exactly at the set point at all times.
thanks
Is there a better, but still simple circuit for doing this?
Thanks for any help.
bipolar transistor and you need a FET (Field effect transistor)
A bipolar transistor drive current if current flow throught
it's base. A FET drive current if Voltage is applied to it's
gate (it remplace base). And a Mosfet is different that a fet
and won't work either.
