3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Power LED's - simplest light with constant-current circuit
Step 3Wire the LED
wire the LED
connect leads to the LED
1 comment
May 12, 2010. 4:29 PMEmmettO says:
 Can this circuit be used to drive multiple LEDs? If so, would they be wired in parallel or series?
Oct 28, 2010. 9:05 AMvanmankline says:
I'm not an expert on this topic, but I'm learning.... From what I know:
You would need to switch out the resistors and ensure the other components can handle the current you require. The way these work you will get better results if you wire the LEDs in series.
Oct 28, 2010. 11:02 AMEmmettO says:
Thanks, I eventually figured it out. http://www.instructables.com/id/USB-Mega-Flashlight/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
