Step 2Bypass the DC power input
In my case, I wasn't sure if I'd want to use my router as an actual router or simply as a switch. With that in mind, I decided to make the first port on the router's built-in switch the "injector port." If you were connecting your wireless router to a cable modem you'd just connect it to the port labeled WAN/Internet instead. The process is the exact same as the one I'm following though, just the port is in a different spot. Cycle through the pictures and you'll see the modified instructions for using the WAN port instead of the first port on the switch.
Regardless of what port you chose to use, you must solder pins 4 and 5 to the red (or POSITIVE) lead. Then you solder pins 7 and 8 to the black (or NEGATIVE) lead. Be careful though, ensuring that you don't get sloppy with your soldering and say, link pins 6, 7, 8 together. It can be a little difficult soldering areas that are so close and so small.
The next part is a little hard to explain just in words so definitely check out the pictures. In the bottom of the first picture, you'll see the DC power input area. Normally, the barrel connector from your power brick would connect here to the router. We're going to eliminate the need for that barrel connector port here though. In this particular example, the barrel connector port is facing DOWN. This matters quite a bit. Many of you might be soldering with it point up. Don't want to mix the polarities up at all.
Mouse-over the pics to see what pins need to be soldered where and definitely zoom in.
In my case,
Add Comment
![D-Link Wireless Router DIR-628 Setup [Without CD]](http://img.instructables.com/files/deriv/FDQ/ZBHK/GIYWWBMF/FDQZBHKGIYWWBMF.SQUARE.jpg)
