3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Power Over Ethernet Router Conversion
Step 3Make the power adapter end
  • last photo ←
To finish off the project, we have to make a cable that will connect our computer to the router for LAN access as well as connect our router to it's newly defined power input. The process is fairly simple:
1. Measure out about 15 feet of cat5 cable. I say 15 feet as a guideline...some believe anything over 15 with this technique is dangerous. However it's debatable. The above linked wikipedia article makes references to this, but before you solder (anything) measure the resistance of your length of cable in step 3 of this list.
2. Use a cat5 cable stripper (come free with many jacks) or an Xacto knife to gently score the sheathing of the cat5 cable 3-4 feet before the cable ends. This is the end that will connect your DC power supply to the computer's power bar and the ethernet port on the computers network interface card/motherboard. Be careful when stripping though, you don't want to nick any of the twisted pairs inside the cable sheathing.
3. Pull the last 3-4 feet up to give you 3 inches of cable exposed. Now we can see the twisted pairs. Cut the blue and brown pairs out as illustrated. Strip the 4 pairs of their sheathing and then twist brown and brown-white together and push off to the side. Then twist the blue and blue-white pairs together. If you want to see the resitance of your cable, connector your multimeter's teast leads to one of the twisted pairs and check on the short end of the cable.
4. Before you break out the soldering iron, prepare the DC injector end by cutting the cable in half (or any other length you prefer...longer might be better if the power bar is say, on your desk). Then strip off the plastic about half an inch or so on both ends. Pull the two wires apart for about a 3 inches and then slip about 1.5 inches of shrink tubing down both ends.
4. However, before we solder anything make sure you have the right polarities figured out. The twisted together blue/blue-white wires get soldered to the positive wire. In our case, this is marked with some writing on it by the manufacturer. Simply twist the two together and solder. Then repeat the process, twisting together the brown/brown-white wires with the negative wire on the connector.
5. We're almost done here. Now, just slip the shrink wrap over the wires you just soldered and use a heat gun or torch to shrink. TIP: I couldn't find my heat gun...so I just moved the soldering iron down the tubing leaving half an inch or so of space between the tubing and iron. Next, slide up the wider piece of shrink tubing (in my case it's white) up to cover those shrunk connections. I'm usually quite thorough with this step of the process -- you don't want anything making contact and shorting out.
6. Last, we'll slip on some cable booties and terminate the ends on this injector cable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:lonjim2
