Power PC Fan Using LED Driver
Introduction: Power PC Fan Using LED Driver
PC fans are cheap, quiet, consistent, and abundant. Compared to fans you can buy retail on normal house AC circuits they are superior in every way. I will guide you through the easiest way to run one.
Cost breakdown
Fan ~4$
Driver ~2$
get a free ride off of a different device's power cord (free)
or dedicated power cord Scrap(free hopefully) else 1 - 3 $
solder, heat shrink, elect tape, etc (cheap)
total: 2$(scrap fan + power cord)
total: 7$(all new)
Step 1: Pick Your Fan
From your fan we need to confirm the Voltage, Current, and Circuit type. For most pc fans it will be 12v DC and you just need to get the current rating.
The fan i used is from ebay:
Circuit type: DC
Voltage 12v
Current 0.36A ( 360mA )
Step 2: Pick Your Driver
So i need to convert my AC home circuit 220v / 110v to 12v dc
Now we want to use a current limited power supply that gets close to 12v and is close to 360mA
These are usually marketed as LED drivers, or transformer for LED strips. Need to make sure they are very close and not exceeding the fan current rating(this kills the fan) also max voltage should be12v or less.
this one is great for one of my fans 320ma12v
this one i can run 3 of my fans on 300ma 36V
Step 3: Hook Them Up!
Red to red, Black to black
If using one fan, its easy just make sure you hook up fan to output marked on driver... and input into a power cord that plugs into your house outlets.
If hooking up multiple drivers (say you want to hook up fan with your led lights driver) to one power cable, do it in series.
If using more than one fan on your single driver hook them up in series, + to - + to - make a big loop.
Here it is running:
Here's another one:
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    great use for those little led drivers. I have a couple left over from a set of LED spots I put in a car. now i have something to use them for. thanks
    It's not necessary to drive a fan or a motor with a constant current. They don't draw more power than whats necessary to turn them under load. Excessive voltage will be the one to watch.
    i know it's not necessary but the constant current driver is cheaper / smaller than dc 12v wall warts i found. Also could be helpful if you were to put a fan in circuit with LED lights.
