I was able to reduce my power consumption and still maintain availability with a little help from technology! By making use of DD-WRT and my computer's BIOS settings I am now able to access my computer remotely when needed and allow scheduled tasks to run without having to leave my computer on all the time.
I used the open source DD-WRT firmware to set up a wireless bridge between my access point and my PC which is in another room. That allowed me to use Wake On LAN (WOL) to power up my computer remotely. I then changed the settings in my computer's BIOS and in Windows to allow WOL to start my computer from whatever state it was in. Lastly I used a BIOS setting to power my computer on every night at 3AM for scheduled maintenance tasks.
To complete this project you will need:
2 Linksys WRT54GL routers or any other supported router
1 Energy Saving Smart Strip
A couple of short ethernet cables
A few hours
A bit of patience!
Follow along to see how it was done!
Remove these ads by
Signing UpStep 1Setting Up The Wireless Bridge For Wake On LAN Capability
WOL does not work over wireless so I needed a wireless bridge connected to my PC's Ethernet port. Buying a second router and configuring DD-WRT to act as a bridge was actually $20 cheaper than buying a true wi-fi bridge and it allowed me have 4 devices bridged instead of just one. Here's how you can create a bridge using two WRT54GL routers:
1. First thoroughly document your current network setup including SSID, WPA passphrases, MAC filters, port forwarding rules, etc.
2. Load DD-WRT firmware on one of the routers and connect it to your internet connection. This will be your Access Point.
*WARNING* Flashing your router's firmware with a third party firmware could turn the device into a "brick" if done improperly. Follow these instructions carefully to avoid any unpleasant surprises.
3. Reconfigure the router with your original settings.
4. Test to make sure your newly flashed router works with all your computers.
5. Flash the firmware of the second router with DD-WRT and configure it with your wireless network's settings. Choose "Client-Bridged" in wireless mode. This router will be your bridge.
6. Add your second router's MAC address to the MAC filter list on your AP.
7. Connect your PC via Ethernet cable to the bridge and check for internet connectivity.
8. Change the settings on your AP to enable remote management. You can set them for whatever security level you prefer. I chose to use HTTPS only and not display an info page to un-authenticated users. These settings are available when you open the Administration page.
Check out the DD-WRT wiki for more detailed instructions on installing DD-WRT and turning your wireless router into a bridge.
If you don't want to buy two WRT54GLs you should be able to get by using one as a bridge and forwarding its managment port using whatever wireless router you currently have. Just a thought. YMMV.
Congratulations. Now you have a wireless bridge in place. Time to work on configuring your computer to be turned on remotely.
Windows Live OneCare is no longer available for sale and product support has ended
What's changing?
As of October 2009, Windows Live OneCare sales were discontinued in all markets. Product support ended on April 11, 2011. In addition, billing support will end on or before June 30, 2011, depending on the customer's subscription end date. View frequently asked questions about the end of sale and support for OneCare.
What do I need to do?
Because OneCare will no longer be actively helping to protect your PC after April 11, 2011, we recommend that you choose another antivirus solution (such as Microsoft Security Essentials, the no-cost, easy-to-use antivirus solution for home and small business customers with PCs running genuine Windows). Before you install another antivirus solution, however, you will first need to uninstall OneCare from your PC.
Regardless, I commend your desire to save power which equals saving money which is always awesome.
http://www.spaceandscience.net/id16.html (oops, sorry Mr. Gore)
Brrr...feel all that global warming? Pass me a parka!
But very cool Ible! I have a few routers that I will be flashing to DD-WRT. Another Ible has to do w/ physical mods to keep it cool.
I want to connect two wirless netgear router with each other . How i do to do that
http://members.shaw.ca/nicholas.fong/vnc/
I had been hesitant to do this as I was going to try to use the SSL VPN but decided to change firmware to the generic version so I could give Kai a whirl. Good times!
I used the calculator on http://michaelbluejay.com/electricity/
I'm not sure exactly how much my computer uses per hour but it has a 450 watt power source and quite a few internal devices like two CD/DVD drives and a raid array so I am assuming it is on the high side of things. For that reason I selected the "240(computer + 17" CRT)" running for 24 hours a day for 31 days a month on the calculator. That added up to 179 kwh per month costing $17.6 per month or $211 per year. I then compared that to using my computer for 3 hours a day which cost $26 per year plus an estimated $8 per year for running the router 24/7 (assuming it uses about 8 watts per hour).
$211-26-8=$177 saved in a year.
Let me know if that doesn't sound right an I will adjust it accordingly.
