Power Supply LM317
3,189
57
7
Posted in TechnologyElectronics
Introduction: Power Supply LM317
About: We are group of young engineers. We like to build stuff.
In these instructable we are going to show you how to make digital power supply using LM317 adjustable regulator, and Arduino pro mini. We added ultrasonic sensor which is used to control output voltage.
Output voltage depends on resistance R2 (picture 4, picture from lm317 datasheet). If you change the resistance R2, you change output voltage. We are changing resistance R2 with parallel connection of the resistors. We are controlling 12 resistors, that means we can get 2^12 (4096) different resistances and with that different output voltage.
Power supply can output voltage from 4,3V to 12V (0,1V Precision). We added 250 ohm potentiometer, so you can lower buttom line to 3V (and with that upper line to 7V).
Its max current is 5A.
Step 1: Parts
For this instructable you are going to need following parts:
- Voltage/current meter________(1)(link)
- On/off switch_______________(1)(link)
- 3D printed parts
- Fuse holder________________(1)(link)
- Ultrasonic sensor____________(1)(link)
- 1 Pair Banana Plugs__________(1)(link)
- 1 Pair Banana connector_______(1)(link)
- 1 Pair Alligator Clip____________(1)(link)
- Circuit
- Button switch_________________(3)(link)
- Power adapter (16V), (64mm x 42mm x 129,5mm)
- 12v ventilator_________________(1)(link)
Step 2: 3D Printed Parts
Power supply is designed in Fusion 360. It is made out of two parts. We added .f3d files, so you can modify housing in fusion 360.
Step 3: Power Adapter
Place power adapter in housing (picture 1). We are using 16V input for circuit (max input voltage for circuit is 30V).
Step 4: Electronic Circuit
Make sure that your circuit board is small enough to fit in housing of power supply.
Blue elements (picture 1) are add on, and you don`t need them. Potentiometer is used to regulate output voltage, and switch is used to chose between manual (Potentiometer controls resistance) and digital mode (arduino controls resistance).
2k ohm resistor -> D0 (Arduino pro mini)
1,8k ohm resistor -> D1 (Arduino pro mini)
1,6k ohm resistor -> D2 (Arduino pro mini)
1,4k ohm resistor -> D3 (Arduino pro mini)
1,2k ohm resistor -> D4 (Arduino pro mini)
1,1k ohm resistor -> D5 (Arduino pro mini)
1k ohm resistor -> D6 (Arduino pro mini)
900 ohm resistor -> D7 (Arduino pro mini)
800 ohm resistor -> D8 (Arduino pro mini)
700 ohm resistor -> D9 (Arduino pro mini)
250 ohm resistor -> D10 (Arduino pro mini)
100 ohm resistor -> D11 (Arduino pro mini)
Ultrasound sensor : trig D13, echo D12
Red button: A0
Yellow button: A1
Green button: A2
Step 5:
Connect and install buttons, fan, switch, fuse and voltage current meter.
Step 6: Program It
Program arduino and test power supply.
Step 7: Tighten the Cover
Tighten the cover with M3 x 15mm screws.
Step 8: Cables (banana - Aligator)
Solder wires on connectors.
Step 9: Cable Holder
Cut rubber band and bind it gently on housing (picture 2), and your power supply is ready to use.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    7 Comments
    Interesting project. What is the part number of the BJT?
    Thank you. I used S9014, but you can use any similar transistor, just make sure it is NPN.
    Interesting way to control the LM317!
    I think your R1 feedback resistor on you circuit diagram should go to Vout though.
    I would also add some capacitance on the output for stability and low ripple.☺
    You are right, my mistake. Thank you for the information.
    I have to say that using ultrasonic sensor is very clever and can be useful on the field, you could have deported it to do the setting with foot while your 2 hands are busy ?
    Great Instructable!
    I'm just confused why you would use an ultrasonic sensor to control your voltage output?
    Thank you! You can use ultrasonic sensor when you have dirty (Motor oil) or wet hands.
