Power Battery Draining Devices With a Power Supply
1,397
23
4
Published
Introduction: Power Battery Draining Devices With a Power Supply
About: -----------------------------------------------------------------15 year old, sick with a deadly disease called DIY-itis!-----------------------------------------------------------------Hi FTC! My I'bles con...
These are some of my devices that I power and use with an outlet socket instead of batteries
If you want too see another one of these, I did this to my drill, this is a pretty complicated project, but if you are interested you can see it here
Step 1: The Remote of the Spy Tank Camera
This spy remote uses 4 AA batteries
4b X 1.5v = 6 VOLTS
I didn't have a 6 volt power supply but i did have a 6.7 volt power supply, So...
How do you turn 6.7 volts easily and quickly to 6?
I connected a diode that lowers the voltage by 0.7 VOLTS with the right polarity to the battery terminals,So, Now, I have a 6 VOLTS power supply and I don't have to waste any money on new batteries!
If you want to learn more about how to connect a diode here is a really helpful tutorial
I just want to say a quick thanks to "Ruslzplace" for a calculation mistake I made.
Step 2: Spy Tank
For this one, The procedure was way easier:
The spy tank works on 6 batteries
6b X 1.5v = 9 VOLTS
Luckily, I had a high amp 9 volt power supply in my collection so it wasn't a big problem
Step 3: By the Way
I have a box of extra power supplies I know I will use for future projects
I really recommend doing this
For those of you that are thinking "Oh, you can use rechargeable batteries!"
For stuff that uses batteries I use only rechargeable batteries, But even 3100 MAH batteries don't last long enough, And, If I want my gadgets to be portable I didn't cancel the option to use batteries, i soldered right to the battery terminals.
If you like these kind of projects, make sure to visit my Instructables page
And, if you have any questions or if you have any problems with the calculations, feel free to ask me in the comment section:)
This can also be really good for the baby beds (idk the name) that shake and play music because they always stay in the same place in the house
Please help save the environment by sharing this project with your friends and family!!!
    • Make it Move Contest
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    4 Comments
    I have a boatload of different ac2dc power systems that I use a lot.. Just have to make sure the Ma output is close to but not OVER what the system needs.. I learned that the hard way.. Haha... R
    Oops, Thanks for pointing that out!!!
    I made a big mistake , I meant to right 6.7 volts and after the diode 6 volts...
    Luckily I made this mistake while typing and not on the trakr itself...
    Thanks for correcting me and I will fix it today :)
    No problem, I thought maybe that was it, but some might get a bit confused seeing it.. Lol I have run saws and drills (110, 115v ) right off my truck battery without an inverter.. But you be careful or risk burning out the alt\gen.. Sometimes, you just have to make it work.. But I had a high amp output on my alt.. Hahaha
