3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Power to the Super Rebound
Some days ago I bought a Tyco Super Rebound at eBay. The Super Rebound is a toy, it's a remote controlled car driven by a rechargable battery.
The car is really fun. But because the car is used and the batteries are old, the capacity of the batteries do not last long. I needed to recharge often. I thought about buying a new battery pack. The thing is that the battery pack is very special. I got a shock seeing the prices, around 29,-$. I took a look at the batteries and found out that these things are poor nicad types. The capacity is rather low and nicad batteries are likely to have the memory effect. Then I took a look at the charger ... oh no, it was one of those cheap and simple constant current chargers. These beasts kill the batteries!
So I decided to buy some nimh batteries with mre than 2500mAh capacity. More as twice the capacity of the original ones. To keep the batteries in good shape I also bought a charger that works with delta voltage charging. Using this charger it is possible to charge the batteries in short time without destroying them.
You need:
- soldering iron
- cutter
- proxxon (or dremel)
- glue
BTW. the "Reading Man" is one of my greatest supporters! He always knows how to do things and he tells me .. ;-)
Step 1Removing the old cells
First of all you needed to break the plastic case of the battery pack. I don't like to dremel .. I like to proxxon .. ;-)
Cut the case along the side and cut deep enough so that you can see the cells inside. Do only cut the main plastic case not the cut the hinges. Because you can not cut the case complete the rest has to be done by putting a screwdriver in the slit and break the case. Be careful but steady ;-)
Take out the batteries and remove the wires.
44 comments
1-40 of 44next »
Aug 24, 2011. 12:33 PMrc trucks man says:
I find this website quite good for batteries, chargers, radio equipment etc, very reasonably priced:
www.nitrotek.co.uk
Maplin is quite good for most things (not radio equipment)but can be a little expensive
rc tanks fan
Nov 12, 2010. 11:18 AMzack247 says:
if you havent found a solution yet, get some of those cheap glass lightbulbs from cheap dolar store toys. they look like small glass bulbs and can have voltage run in either direction so they would be perfect for attaching to the motor directly. you may need a resistor though.
Dec 27, 2009. 7:42 PMsarujin says:
I have one of these cars too.  Unfortunately, I lost the remote.  Any advice on how to get that project off the ground would be good.
Sep 30, 2010. 9:11 PMjongscx says:
Buy another RC tank, rip the control circuits out and transplant them...
That, or look for someone selling just the remote. These usually used only one or possibly two different frequencies (that's why you could never race your friends with the same kind of car), so buying another one would probably work.
Oct 9, 2010. 9:17 AMSlugFest23 says:
Also if you are after a few cheap parts you can contact some of the main RC sites for spares. I got some parts for RC Tanks here. Good luck!
Sep 12, 2010. 4:54 PMthe gizmoman says:
Instead of nimh try using lipo batteries they are lighter and more powerful then nimh
Sep 30, 2010. 9:09 PMjongscx says:
And also explode if charged incorrectly... I think his objective here was just to return the toy back to working condition with what he had on hand or at least improve it without taking that much effort.
Yes, LiPO would be a lot better technically... but he'd have to buy new cells, a battery mgmt system, and a charger or at least design the last two...
May 17, 2010. 6:07 PMrapidprototyping says:
Wally
Mar 25, 2010. 3:37 AMjoeofloath says:
I had an origianl rebound. I found it after 10 years in the loft, and rebuilt it with an 8 cell ni-cad pack from another model (original was 5 cell). It went about 25mph, was indestructible, and would climb anything. It got boring when I bought a hobby grade RC though (as well as one of the motors slowly dieing and it driving in lazy circles), and I chucked it.
Dec 6, 2009. 8:59 PMstunami says:
Wow! I've been wondering about how to go about this exact same thing with my RC motorcycle! Thanks!
Dec 5, 2009. 11:26 PMbeackmaniax says:
cool !
how much does it last without recharging?
Sep 27, 2009. 2:08 AMmarko9871 says:
HI... I just found original Rebound 4x4 in my closet. It was there for some years and i remember that battery was rly bad and i stoped using it... After some time on google i found that artcile and its rly great... But i have problem... My Rebound have difrent type battery (chek image). Does someone know if the are 6AA bateries inside to?
http://ecx.images-amazon.com/images/I/717P2Z1BTML._SL500_AA280_.gif
PS: bad english :)
Dec 5, 2009. 5:25 PMfishgish509 says:
thats not bad english
Oct 17, 2006. 10:11 PMelectronicfreak22 says:
Is it possible to destroy alkaline batteries when you solder them?
Nov 18, 2006. 7:59 AM_soapy_ says:
He means "warm".
Self-discharge is an issue with most batteries. Higher temps cause it to happen faster, and some batteries lose all charge if allowed to get below 0oC.
Least self discharge
Non-rechargable Lithium Iron (10 year shelf life)
Rechargable Lithium ion (over 1 year with no noticable effect)
Alkaline (about 4 years)
NiMh (not sure, a few months?)
Sealed Lead-Acid (about 3 months)
Lead Acid (About 3 months until dead)
NiCd (often a few weeks!)
Most self-discharge
Comments and corrections welcome!
May 22, 2009. 6:06 AMarikyeo says:
most problably...no. Just buy a Canon camera battery NB-4/5L (dat's LIoN not LiPo) and get the external charger and wire the charging terminals of the charger to any male jack that supports it and wire the terminals of the battery to a matching female jack. It worked for me and I did dat cus' I got the set when I traded in my old camera for a new one and forgot to include the battery pack set. Luckily Canon did not run a big chase with me over it. :-}
Nov 25, 2006. 6:05 PM_soapy_ says:
Not that I know of. I don't really know much about these highest powered batteries (weight-for-weight). I'd advise looking at the micro-flier websites, as the very small light aircraft guys run these batteries very hard, and demand the best from them. I've seen quite a few explosions from them being abused, both in charge and discharge, though. Probably not something for your 6yo to play with!
Sep 13, 2006. 9:13 PMtheRIAA says:
nice clean up there... if i was gona mod an electric car i would probly just tabe some extra batteires on it.... *flashback*, OH YEA, once i had one of those super tiny RCs and i taped 2 AAs on the side and wired it up (like 3 times the volts), it went SUPER FAST!!!!... so naturaly... i took the AAs off straped a 9-volt on top, wired it directly to the motor and batery, adn DAMN!!!! it DID DOUGHNUTS ON CARPET!!! it was INSANE... then... i sment burning and it didnt woek anymore D:
May 22, 2009. 6:00 AMarikyeo says:
dat did happen to me once. I wired a 2CR2 battery onto a R/C car which was supposed to use only 2xAAAA batteries and it shorted out and turned into a greeeeeeeaaaaat display of a multi-coloured light show!!! :-)
May 2, 2009. 8:45 PMarikyeo says:
Wont it short out the car? Ive tried it, changing form the default batteries(600mAh, niCd) to mine(2700mAh, NiMh).It worked for a min., thenthe car was so hot it stopped working!!!
Jan 22, 2009. 2:18 AMFRIO ECUADOR says:
Hey! nice work, I'been working too with mine. I'm adapting the super rebound tx/rx with another r/c vehicle. I'd like to ask you a small favor. Recently unmounting the rx I've just cut the antenna and now I don't know where is it supposed to be soldered on. It would be very nice if you can check your rebound and help me. thanx!
Jan 4, 2009. 10:20 AMZaphod Beeblebrox says:
I try to get rc cars with normal AA batteries so I do not have to do things like this.
Sep 26, 2008. 5:33 AMsadunpererarules says:
haha. The tyco rebound is the best RC car ever made! i had one when i was 7 about 8 years ago. did u know it is waterproof?, trust me...it is
Sep 23, 2006. 10:27 AMMyself says:
Soldering to batteries is a good way to kill them, you got lucky! Search for "capacitave discharge spot welder" projects on the net. If you rebuild a lot of battery packs you might want to build one of these.
May 2, 2009. 8:46 PMarikyeo says:
Just use wire glue!!! It works!!!
May 24, 2007. 11:02 AMPunkguyta says:
I bought a similar car, except it was one of those ones with three wheels, one big inflatable green one. It was really cool, but I agree, the chargers they include with those things are the shitterz. I should do this to mine.
Sep 16, 2006. 9:24 AMSlimJim says:
Reading Man? That looks more like "Bill Dotreeb" from King of the Hill. Cool instructable.
May 24, 2007. 11:01 AMPunkguyta says:
I'd agree
Feb 9, 2007. 7:04 PMicanryme2002 says:
its not a movie and hes to thin to be bill dotreave
May 1, 2007. 2:03 PMevmatthew says:
What makes you think the old batteries you removed were NiCd instead of NiMH? The Super Rebound was the first of Tyco's toys to make use of the then-new TMH pack, which is supposed to contain NiMH batteries. They just get tired after a few years. Great instructable! I now plan to do this to several of my TMH packs! (I have many of them!)
Sep 15, 2006. 11:03 AMhollasch says:
How much did you spend for the final setup? While I also feel that $29 is robbery for this battery pack (particularly since Tyco makes you pay for this pack seperately from the toy), it seems that six cells plus a charger would cost a bit as well. Still a very nice mod here.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:frickelkram
radio amateur since i was 16, education in electronics, built extension-cards for ibm pc, build machines to make concrete, studied communications engineering, had a dot-com company in the late ninetie...
more »
