Powered Wheelbarrow Trommel
 by asred
Contest WinnerFeatured
A great way to separate rock from dirt. It's perfect for gardens or in my case landscape rock!
I needed to install a french drain to redirect the rain from the front of my house. The problem was that my house is surrounded by rock beds! I ended up building a powered wheelbarrow trommel to save me from separating the river rock from the good dirt by hand. The trommel will also come in handy for getting all those pesky rocks from my wife's garden. The most novel thing about it is that the trommel sits on top of my wheel barrel so that dirt is dispensed right in the wheelbarrow for easy transportation. Oh, and I built the thing for less than 90.00.
Dimensions
If you'd like to build one for yourself, you'll have to make up the dimensions as you custom fit the frame for your wheelbarrow.
Specs for the basic parts
Gear reduction motor (125 rpm, 1/10hp, 12v, 12 amp)
I used a 3/4 inch pully with 5/8 inch bore, but any size pulley will work.
10 amp manual battery charger
1/4 inch wire mesh screen from any hardware store
The tops of three 5 gallon buckets (two for wheel tracks and one for pulley)
8 castor wheals that fit in the track of the bucket rims.
Rubber floor mat
If you are going to use a garbage can to catch the rocks as they come out of the trommel, you'll find that the wheelbarrow will tip backwards. I shifted my wheelbarrow's legs back 6 inches. The easiest way to keep the cross plate that gives the legs their stability is to turn the legs around before remounting them.
If you'd like to save 15 or so dollars you could forgo the mesh screen and bolt two 5 gallon buckets together and then drill "a lot* of 5/16 in holes in buckets to simulate a screen. It works. I tried it, but it won't perform as well as the mess screen.
Get a wheelbarrow with two wheels! I overloaded the wheelbarrow a few times and almost it.
heathbar64 says: Jul 3, 2012. 1:25 PM
Very nice! I can't tell from the pictures, do you have the drum slanted, or how do you make the rock travel down and eject into the trash can?
asred (author) in reply to heathbar64Jul 4, 2012. 6:20 AM
Good question. The drum is mounted level on the wood platform. The wheelbarrow is what puts it at an angle. I found that the longer the rock/dirt stayed in the drum the cleaner it got. So at times I used blocks to raise the back end of the platform so that it is slanted by about 5-10 degrees (the video shows no blocks because the wheelbarrow was already adjusted by the way it was positioned on the ground) . It's all about finding a good speed to angle ratio for loading the drum efficiently. The drum spins fast enough to move the rock through by the time I filled my shovel and was ready to load the drum again. Depending on your motor, if you find that it doesn't spin fast enough just put a bigger pulley on the motor.
Schmidty16 says: Jul 3, 2012. 9:28 PM
use it for gold mining dude get gold mmm gold fever
CupcakeGizmo says: Jun 29, 2012. 2:25 PM
Nice! Time to go to Alaska.. No guts.. no glory!
WrshpMzshn says: Jun 28, 2012. 5:19 PM
I like it! Any idea how long it'd run on a car battery? It could be taken into the "field" and used for gold prospecting.
asred (author) in reply to WrshpMzshnJun 29, 2012. 6:54 AM
That I couldn't tell you. There are too many variables to consider. The motor is actually rated for 12 volts and 12 amps. You could plug it into your car without a problem and just leave your car running to charge the battery which powers the motor.
rimar2000 says: Jun 21, 2012. 4:19 PM
What a good idea!
asred (author) in reply to rimar2000Jun 21, 2012. 7:11 PM
Thanks Rimar2000. It's saved me lots of time. I was able to move a 20X10 section of river rock in one day.
What a good idea!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
