Powerful K'nex Gun
450
Published
Introduction: Powerful K'nex Gun
About: I like to build weapons in my spare time.
This is a powerful gun made of K'nex that shoots wire ammunition with a rubber band.
Step 1: Materials
You will need K'nex pieces, duct tape, a rubber band, a flat piece of plastic, and a clothes pin or clip.
Step 2: Frame
Build both these pieces. You will need 24 yellow, 16 silver, and 20 black.
Step 3: Connection
To connect the two frames you will need 3 purples, 1 red, 8 silver rings, 8 light blue rings, and 2 blue clip pieces.
Step 4: Handle
To build this you will need 4 yellows, 2 blacks, and 1 silver. Then wrap the handle with duct tape.
Step 5: Support
This will add support to your handle. You will need 1 yellow, 1 grey, 1 white, and 1 purple. Then wrap with duct tape.
Step 6: Track
This will let the wire ammunition glide easily as it is being fired. Any flat piece of plastic will work, but I used an old hot wheels track. Simply tape this on top of the gun.
Step 7: Clip
This acts as a trigger for the gun. Simply tape this to the top of the gun.
Step 8: Rubber Bands
Tape to each end of the red K'nex piece.
Step 9: Ammunition
Bend wire into this shape with needle-nose pliers.
Step 10: Shoot
To shoot simply hook wire onto rubber band, pull it back and clip it in the clip, then aim and shoot. I AM NOT RESPONSIBLE FOR WHAT YOU DO WITH THIS GUN.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    Truly a step forward in the advancement of K'nex innovation
    This uses pretty much tape, try to make it stronger with knex parts.
    Nice, although you should try and make a knex gun from just knex, with the exception of a rubber band
    Isn't this just a big sling shot?
