Powerfull Manageable 15k RPM HDD Grinder With Continue Rotation
3,149
52
5
Posted in TechnologyElectronics
Introduction: Powerfull Manageable 15k RPM HDD Grinder With Continue Rotation
Today we will create a powerfull manageable 15k RPM grinder with continue rotation for less 5€.
Step 1: Parts Required
- An old SAS HDD 15k RPM
- 12v, 2A step down transformer
- Sand paper
- Double-sided self-adhesive
- Hacksaw
- ESC 30A
- Servo tester
Total no more 5€
Step 2: Mecanic
Open the HDD & remove front cover, actuator & magnetic disc.
Cut the top plate in half and do the same with the bottom plate.
Now take the magnetic disc, cut same size of sand paper & stick it on the disc with double-sided self-adhesive.
You have done the mecanic part, now to go the electronic part.
Step 3: Electronic
Now replace the old hdd controler card with the ESC.
Weld ESC to the motor drive, connect it to the tester and add some hot glue to secure wires.
It's complete, all that remains closed the grinder and connecte to the transformer.
You have now a powerfull manageable 15k RPM HDD grinder.
Step 4: Video and Improvements
As you can see, I put a different sand paper on each magnetic disk so that I can change easily.
And I use a magnet present in the hard disk, place it on the top plate to retrieve the metallic chips.
Later perhaps cut more of the bottom plate and add a power jack.
For French, you can find this article on MIWC
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    5 Comments
    Looks sweet. Could you add a video of it working to get an idea of what it can do? How full of power it is?
    Yes no problem, I make a video as possible.
    Theoretically the disc rotates at 15K RPM but I have no tools to check it.
    Ok thank you! I really like this idea. I have 2 old desktop tower computers. I was going to reuse the power supplies and plugs. This is a good way to make use of the hard drives too. Like the Native Americans trying to use every part of the buffalo that they hunted...in the modern day old computers are like the new buffalos.
    Video is here, tell me what you think of it.
    Thanks.
