Powering Your Raspberry Pi With Batteries
Published
Introduction: Powering Your Raspberry Pi With Batteries
I've been messing around with new things to add to my raspberry Pi, and after my last instructable on how to add a switch, I thought that it would be really easy to just switch out the plug end of the circuit with a few batteries. So now i can power it with just 3 AA Batteries.
Step 1: Materials
You will need...
-Raspberry Pi
-3 AA batteries and some way of connecting them
-Normal micro USB power chord
-Some clips or tape for hosing together the wires
-Wire strippers
-Optional -Switch
Step 2: Preparing the Power Chord
Fist off, you need to get rid of the wall plug end of your power chord. Cut it wherever you like so that you have just the part that plugs into the Pi. Now strip off the end so that you have two wires of different colors. Now, Strip those two wires carefully.
Step 3: Adding the Batteries
Now, take the batteries and connect all three of them properly. It's easy to do if you have battery packs like the ones in the picture. Take the two ends of your three batteries and attach them to either end of your power chord. Secure the connections with some clips or electrical tape. Once you've done that, you should be able to plug that power chord straight into your raspberry Pi and start it up.
Step 4: Optional- Adding a Switch
Now that you have the batteries going, it's really simple to just add a switch to this circuit. Detach one end of your batteries from the power chord. Take the end connected to your batteries and attach it to one side of your switch. Now take your other end from the plug and connect it to the other side of your switch. Now you can turn your raspberry Pi on and off with this switch.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    3 Comments
    other than the need to correct "chord" to "cord" - nice job! :)
    Yeah after a while, the keyboard stopped working so I had to change the batteries, but I got a few good hours out of it
    Let us know how reliable this is after a few things are plugged in .... and after the batteries have sagged a bit with age :)
    3xAA batteries = 4.5v. The raspberry pi needs 5v. Actually, 5.25v is recommended for reliable operation. On board, it converts to 3.3v so you may get away with it, for a while.
    Most of the trouble people have with "My pi crashed when I plugged in the mouse" is because of under spec power supplies.
    USB devices may/may not work -- if they really need 5v, you are low. If they internally convert to 3.3v you may get away with it.
    A better idea is 4 AA batteries and an LDO 5V regulator, it's only slightly more complicated but more reliable.
