Powering a NXT Lego Robot With a Cheap Drill Battery / Accumulator
Introduction: Powering a NXT Lego Robot With a Cheap Drill Battery / Accumulator
One of the most important and expensive aspects of designing a mobile robot, is to find the right accumulator that allows long periods of autonomous operation. Most accumulators are quite expensive and modern accumulator technologies, such as LiPos (stands for lithium-ion polymer battery) or NiCd accumulators (stands for nickel–cadmium battery) demand for a specific charging device. In lack of both i was searching for a real cheap alternative to get a powerful accumulator in combination with a charging device that is able to fulfill my requirements.
So finally i came across my cheap accumulator drill set that contains 2 powerful rechargeable batteries with 18V with 1.300mAh capacity and a charging device for around 39€.
Combined with a really cheap L78xx voltage regulator we can choose the demanded voltage for any chosen consumer device.
In this case i had to power a Lego NXT brick, several Lego servos and additionally an Android smartphone device. As the Lego NXT brick operates on 7.2V i took a L7809CV voltage regulator to get 9V out of the drill accumulator (i already checked that the NXT brick worked with a 9V power adapter). You can see the PIN layout of L7809CV (78xx_datasheet) in following image:
You can find the full project and many more at : www.smartlab.at
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    sure you can find it already here, but i will also post it on instructables soon:
