Powertech Toys: King of the Animals by Cy Coldiron
63
Posted in TechnologyGadgets
Introduction: Powertech Toys: King of the Animals by Cy Coldiron
In this instructable I will instruct you how to make a Powertech toy: King of The Animals
Step 1: Battery Plate
The battery plate is pre made piece and is the first piece that you will start off with.
Step 2: Add the Foot
In your next step you must have two foot pieces, small metal rod and two plugs. Put the medal rod through the plastic zip ties and then put the green plugs on the end of the rod.
Step 3: Screw in the Motor
Put the motor on the opposite side of the two feet. Once the motor is placed correctly screw it in through the holes provided. You must also put the plugs through the screw but the plug must be under the platform in order to work.
Step 4: Screw the Long Feet In
In order to finish you must have two long feet, four green plugs and four screws. Once you have those materials screw them in into the corners of the minature. It is very important that you have the plugs on the outer part of the miniature.
Step 5: Turning It Off and On
To finish your Powertech miniature turn the metal switch to the opposite side of the AA battery holder. If the minature is moving forward then you know you're finished. To turn it off you simply turn the switch to to the opposite side. If the miniature is not moving then the miniature is turned off.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    3 Comments
    thanks you!
