At our breakfast counter you see the in-use indicator (red LED lighted in the photo), the phone, the answering machine, and the wall wart power converter for the answering machine.
Remove these ads by
Signing UpStep 1Planned Circuit
The 13 volt current from the answering machine power supply needed to be dropped to about 9 volts for the battery. There may be other, perhaps even better ways to do it. But, I chose to use a string of five diodes to lower the voltage. Each diode drops the voltage about 0.6 volt. In simulation the drop was 0.8 volt.
A circuit that constantly recharges a battery should feed 1/100th of the amp-hour rating of the battery to the battery at all times. The battery is rated at 150 milli-amp hours. The 6 K Ohm resistor brings the current flow down to 1.52 mA.
21
comments
Add Comment
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
terrapinlogo
says:
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
Add Comment
