3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Practice Lightsaber
Practice Lightsaber
Monster funnoodles with a glued wooden handle make excellent training tools for your next duel with Darth Andy.
Step 1Summary
Summary
Tested in the meddle of combat, durable and hard hitting foam lightsabers have taught my padawans much in the way of the force. Costing only a few credits each, they have helped shape their bodies and minds. No blood has been spilled but a battle is well remembered by the combatants.
Not recommended for under 8 years old, anyone who decides that the sword is best used with the wooden handle end out, or going up against professional baseball players. I have not had any injuries for the past 3 years with up to a dozen teenaged boys going at it at once. Still???
97 comments
1-40 of 97next »
Jan 15, 2012. 12:16 PMLilPurpleCow says:
Just randomly... This totally reminds me of a "Struggle Bat" from Kingdom Hearts 2.
:) I will have to go make one of these. Or a collection of these.
Awesome!
May 21, 2009. 6:35 PMthing 2 says:
you could use pvc pipe for light weight and softer brace, so it doesn't hurt when you get hit by the wood part
Aug 8, 2009. 8:33 PMTravelsonic says:
"It is almost impossible to slide in without ripping the foam up" I've done it quite successfully, guess it is just the noodles I use having just a big enough hole for the pipe to slide in easily. As for gluing, I would recommend using 3M Super 77 Adhesive Spray if working with PVC/noodle. Sprays on easily, you'll have to wipe it up with a paper towel off the noodle at the bottom of the pipe near the handle, but that noodle is not coming off. :D
Sep 19, 2009. 6:44 PMdawsonj says:
lol. i made two from a mega noodle and a long piece of dowel. i have been using them for weeks and the only damage is where the cat used one as a scratching post.
Jun 19, 2009. 6:38 PMjames927 says:
It's dark out so I haven't ran out to the pool yet to try this, but just one question, why don't you put the dowel all the way through it? The foam would pad it and it would be stronger... or is it not to flexible anyway? I saw nerf swords at walmart and they have a rod straight through them ($13). I'm used to fighting my brother and little kids with wooden swords and this seems like a great way to pad them so we'll stop hurting each others knuckles. I have a shield made out of half a pallet but when you add spikes to the end so you can punch with it... safety goes down fast. Also, fyi, "grade stakes" (gardening stakes) are what we use for swords and we sell them for $.50 each, so seems cheaper than a dowel. Farming stores probably sell them, just grind the point down and round the handle... Just my thoughts, sorry if it's long...
Oct 6, 2006. 10:53 PMJesus10555 says:
You should add a mastercard pun in that paragraph :)
Aug 19, 2008. 6:28 PMkaerius says:
monster funnoodle: $7 dowel: $3.75 Loctite Quick set 5 minute epoxy with a dual delivery system: $3 hitting your brother with a foam lightsaber: priceless
Jun 14, 2009. 12:08 PMMegaMaker says:
"hitting your brother with a foam lightsaber: priceless" Agreed. But, of course sometimes it also costs a grounding.
Oct 19, 2008. 2:04 PMTravelsonic says:
:monster funnoodle: $7 Rip-off, IMO. Poolcenter.com has them for about $3 each.
Jun 14, 2009. 4:22 PMMegaMaker says:
At Wal-Mart $4.
Jun 16, 2009. 8:51 AMMegaMaker says:
The $4 ones were monster funnoodles.
Jun 15, 2009. 7:10 PMTravelsonic says:
Which is why I recommend poolcenter. Consistent, good quality noodles.
Apr 11, 2009. 4:26 PMOroka says:
Awesome, now I don't have to worry about cutting myself with my real lightsaber.
Apr 4, 2009. 10:50 AMBrother_D says:
Now, why would I buy that when I can make an extremely better one for like $6?
Jan 15, 2009. 9:26 AMTravelsonic says:
This could be good, but it could be bad for those who go into boffer related business - especially if this company tries to patent them (which, despite there clearly being "prior art" isn't impossible given how broken our system is)
Dec 25, 2008. 6:24 AMsnelpiller says:
This is actully pretty good if u wanna do a lighsaber effect in vegas or aftereffects, makes rotorscoping easy
Jan 7, 2007. 8:53 PMhighonlove says:
im srry if someone has already said this but any way
why not put the dowel rod al the way through so its more s{{{
Nov 21, 2008. 11:14 PMTravelsonic says:
On top of that, if the foam for some reason or another tears off, which does happen, the core wont be fully exposed, more important with PVC IIRC, but still good to have.
Aug 7, 2007. 8:07 PMhighonlove says:
well i guess we dotn think the same cuz more it hurts the other person the more they want to defend themselves ya no' lol well pluz u could just us a smaller doweel rod if its so hard
May 6, 2007. 4:24 PMmagganrchy says:
My brothers and i have been making these for a while, if you wrap duct tape around the outside, at least partly then it will stay together better, and you should use pvc pipes instead of dowel rods, because dowel rods break. (i think the size was 1/2, but it might be 5/8)
Jul 2, 2008. 2:16 PMWurdBendur says:
I strongly recommend using a cloth cover. Duct tape will make it hit harder. Cloth will protect the foam in the same way and actually make it softer. For a quick and easy cover, I use tube socks. You can tape the bottom onto the handle or just let the elastic hold it in place. And I agree on the PVC. 1/2" is popular, but I prefer 3/4" pressure pipe (with a 1" outside diameter) because the size makes a better handle. If you do use wood for the core, you should tape it up first in case it breaks, to hold the pieces together and to contain splinters.
Jul 3, 2008. 1:26 AMWurdBendur says:
My two swords are 24" and 25" long, which is notably longer than usual, and each is covered by a single tube sock. And these weren't even the largest size I could find. I just got them because they were black and I thought white socks would look silly. You can also stretch them out before you put them on. But if socks really won't work, you can just sew a rectangle of cloth into a cylinder and close the end. You could use panty hose, but I'm not sure they'll do much good because they're so thin. By the way, 30" is probably too long for the people using them, especially if they're children. I think the longest boffer blade I've ever seen is my brother's at about 38", and that thing is a monster. As a rough guideline, your blade should only reach from the ground to your fingers when your hand is hanging at your side, at least for beginners. Much longer than that and it starts to become unwieldy. And you're right that a 2-foot-long 1" dowel will probably never break. They're just usually longer than that, extending most of the way up the blade. It keeps the blade straight and prevents people whipping it around shields or other swords. Any dowel that long will eventually break, which is why it's best to use a flexible core such as PVC or fiberglass if it's going to be that long.
Oct 19, 2008. 2:07 PMTravelsonic says:
"By the way, 30" is probably too long for the people using them, especially if they're children. I think the longest boffer blade I've ever seen is my brother's at about 38", and that thing is a monster" My hand-and-a-half sword is about 42 inches. Boffers can be quite large, and that is without touching two-handed weapons.
Nov 19, 2008. 9:23 AMWurdBendur says:
But how much of that is blade? That's the length that matters. I've seen tremendous weapons, but almost always with relatively short blades. The measurements I gave are just the blade.
Nov 19, 2008. 3:21 PMTravelsonic says:
My newest hand-and-a-half/broadsword has blade of only 32, shorter than my old hand-and-a-half but not by that much really though the length in my last post I gave was for overall weapon meaning that if I wanted I could make a small pommel, decent hilt, and have a blade that exceeds this while still fitting in the broadsword/hand-and-a-haf lengths limits of the college larp I am involved with.. The claymore I made has a blade of about 40 inches in length. Overall length is about 63 inches.
Nov 21, 2008. 3:05 PMWurdBendur says:
It it was more than a pound and a half or so, it was probably not accurate.
Nov 19, 2008. 8:52 PMTravelsonic says:
"hat is why I can recommend my swords to any age. The youngest to swing and hit me had diapers on and was holding onto Mom's skirt to balance. That is how light my swords are even at over 35" long overall." Depends on what you use. A 38 inch boffer made with pvc will be heavier than one made with graphite core for example.
Nov 21, 2008. 3:17 PMWurdBendur says:
Most people who use pool noodles let it extend about 3-4 inches past the end of the core, so it shouldn't come through. You can also cut off a small piece and stuff it in the hole to make it safer.
Nov 21, 2008. 11:34 PMTravelsonic says:
Not just pool noodle, IIRC NERO does require 2 inches off the pipe for the pipe foam boffers.
Nov 19, 2008. 3:26 PMTravelsonic says:
It may be for little children, the intent of the stuff used here, but outside of that - say college LARPS or event-run LARPS, 28-30 is nothing. Longer length, if you use it correctly, can give you a good advantage with regards to range, so long as you aren't up against a dual-wielding maniac of an opponent.
Nov 21, 2008. 3:27 PMWurdBendur says:
I wouldn't say it's nothing. It's larger than average for blades, after you throw out the giant fantasy swords that few can wield effectively. Those would be better as shields anyway. I've learned to use long weapons fairly well, but at some length they become impractical. I also found that I became much better at using my shorter swords once I had got used to my brother's monster great sword.
1-40 of 97next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:johnpombrio
