Introduction: Practice Rope Dart & Meteor
Picture of Practice Rope Dart & Meteor
Rope darts and single headed meteors are very similar, the only difference is that the meteors use blunt heads while Rope darts use piercing heads. Here are instructions to make a simple practice object
Step 1: Materials
Picture of Materials
You will need a lacrosse ball or hard rubber ball, an eye screw, and 8-15 ft. of rope (I like nylon because you can burn the ends and they won't fray).
(optional) - Power drill with a very small drill bit (make it alot smaller then the eye screw)
Step 2: Making the Head
Picture of Making the Head
Take the eye screw, apply pressure, and twist it into the ball until your at the base. You can use the small drill bit to start the hole which will make it a lot easier.
Step 3: Tying the Head
Picture of Tying the Head
Take the rope, thread it through, double it up and tie it. If you don't know what i mean its the same knot used to tie poi. (Here's a video I found http://www.youtube.com/watch?v=3Gx0z2gdLLo )
Step 4: Practice
Now here is the fun part, go out and use it, if you don't know where to start here are some videos I've found
http://www.youtube.com/watch?v=7LH7CHey_5o
They have an entire series that this one links to so I won't post them
Step 5: Extra: Handle Loop
Picture of Extra: Handle Loop
Now that you've played a bit and figured out how long you like your equipment time to make the handle. Just like with attaching the head, make the double knot and your done.
Ryburrr (author)2015-10-26
not to be too critical here, but sinking an eye bolt into rubber is not the best idea, as the threads will eventually pull out, especially with the forces generated by a meteor! You COULD anchor the eyebolt in with a permanent adhesive...
Think_Design_Build (author)2015-02-24
Won't the lacrosse ball eventually fly off? How well does the eye hook hold into the ball?
About This Instructable
5,065views
15favorites
License:
More by acatrambone:Practice Rope Dart & Meteor
Add instructable to:
