Prank/Secret Storage - iPhone USB Cable
 by Mr_o_uk
Contest WinnerFeatured
2013 10:43.jpg
I had a USB memory stick that had fallen apart, and I had an iphone USB cable that didn't work. So I thought about combining the two and making a secret USB storage cable, which can then be used to prank people.
I used an iPhone cable as I had a broken one, but you could do this with any USB cable.
Date made: March 2013
Approx Cost: £0 - reusing old broken stuff
Approx Time: 0.5 hours
Difficulty: Easy
Step 1: Things You Need
2013 14:50.jpg
2013 14:50.jpg
2013 10:43.jpg
2013 10:43.jpg
2013 10:43.jpg
1. iPhone cable
2. Scissors/knife
3. Glue
4. Rubber/Eraser (optional)
5. USB Storage.
I had a cheap copy of a LaCie USB key. It wasn't very well made and the cover kept splitting, and the internals would move as they weren't stuck down well.
I threw the case out in the end as the internals moved and connectors would touch the metal case. Not clever.
I kept the inside though as it still worked fine.
For this task, you need a similar type of USB storage; a very small flat one! I'm sure there are plenty out there.
jcano yribarren says: Mar 21, 2013. 2:55 PM
You can create an autorun dummy program to say "Format in progress. Please whait" or something like that
workislove says: Mar 18, 2013. 5:23 PM
Haha, I love it. I have a second, beat up cable that this would be perfect for.
chawla_mohali says: Mar 12, 2013. 11:37 PM
Neat!! :D
bird123457 says: Mar 12, 2013. 10:34 AM
As a secret way of storing content this is a very good idea, but how is it a prank?
Mr_o_uk (author) in reply to bird123457Mar 12, 2013. 10:34 AM
Name the storage drive "iPhone", Fill it with folder names that match that of an iPhone, but instead fill it with blank photos, warped photos, dodgy photos or some type of photo your friend wouldn't like (think phobia or scary)! Then when your friend uses it to plug in their iPhone, they will be surprised/worried by the content, or think they have a virus, as it doesnt match what should be on their phone! Alternatively, as someone else suggested, you could put a programe on it that would do something to the victims computer - they would think it is trustworthy at its connected to their own phone.
DanYHKim says: Mar 12, 2013. 8:30 AM
This could be used to conceal data from search, since a "cable" is not suspected of being a storage device. You could travel with a laptop that has a rather bland setup of Windows on its hard drive, then load up your subversive liveUSB Linux system from the USB storage drive.
4lifenerdfighter says: Mar 12, 2013. 6:02 AM
Make a program that installs a Linux partition on the victim's hard drive.
Mr_o_uk (author) in reply to 4lifenerdfighterMar 12, 2013. 7:43 AM
I didn't think of that, but yes, instead of photos you could put programs on there. They will believe its trustworthy as they think its linked to their phone!
zews says: Mar 11, 2013. 5:46 PM
and very sneaky
Dookster says: Mar 11, 2013. 12:14 PM
This is pretty good but you can connect the wires from the cable to the back of the pads to keep a functioning cable.
Mr_o_uk (author) in reply to DooksterMar 11, 2013. 4:12 PM
Do you mean connect to the USB storage pads? I can't see how this would work, as I think you can only run 1 USB at a time when things are spliced, and there is no way to 'turn off' or 'unplug' the storage.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
