Step 4Taking measurements
- the width and depth of the miter slots
- the distance between the miter slots, and where the saw blade sits between them
- the thickness of the blade itself (this is called "kerf"), and also its maximum depth of cut
- the thickness and diameter of any blade dampeners or stiffeners that you plan to use
- how far back the blade sits from the front of the saw
- how far the saw is front to back, and how much travel the sled will have
Making accurate measurements is an art form in and of itself. The thousandth of an inch (0.001") is a popular dimensional increment, and there are a wide range of readily accessible (and occasionally reasonably priced) tools which will take certain measurements accurate down to one thousandth. By far, the most versatile of these tools are four-way dial calipers. This picture shows my drawer of inspection (i.e. measuring) tools -- I've got three sets of calipers in there.
I strongly recommend that you get yourself a set of calipers. I will make several more tool recommendation throughout the course of this project, but this one is by far the most important of them. Although you won't actually need calipers to build this sled, you will need them to calibrate your saw and jigs, and to measure for error in the resulting cuts. Your cuts can only be as accurate as your ability to measure.
Add Comment
