Precision Wire Stripper - New Video Links
21,773
50
15
Posted
Introduction: Precision Wire Stripper - New Video Links
Manual rotary wire stripper from a Bic pen, a screwdriver, and a razor blade.
I recently bought a spool of 30AWG teflon wire. I thought it would be great for prototyping, because a hot soldering iron won't melt the insulation. Well, it's sort of not great at all... the problem is this wire is hard to strip. None of my wire strippers worked, including my DIY "hot tweezer" stripper. The only way I could strip it was with a a razor blade and a lot of care. So after a lot of thought and a couple of other prototypes, I came up with this.
Here's a video link:
http://www.youtube.com/watch?v=TJzRcn9hIZU
Here's a vid of my homemade nichrome wire tweezer stripper:
http://www.youtube.com/watch?v=K2hXvcF6ANU
Step 1: Action
A V-shaped cutting edge resides on the end of the tip. You hold the wire in a pair of pliers, like so, and you slip the tool over the wire. Holding the tool flat against the pliers, you position so that the blades contact the insulation. Then you carefully twist the tool, keeping pressure towards the wire.
Make one or two complete revolutions.
Step 2: Stripped!
Now, dislodge the tool from the wire. As you are slipping the tool off of the wire, you can now grab the insulation with the tool and slide it off.
If you think this is a lot of trouble to strip a wire... it is. But if you have ever stripped 30AWG teflon wire and know of a better way, then please post it!
FYI, a "hot tweezer" stripper works great on regular wrapping wire.
Step 3: Construction
Take a Bic pen. Remove the collet that holds the tip. Save for later. Cut the barrel into several one-inch sections.
Take some standard razor blades, as for window scraping. Put on safety glasses. Snap them into little bits. Keep snapping until you get two good size blades for each bit of pen barrel.
Lay the blades out into little "V" shapes.
Now mix up some epoxy. Apply to end of pen barrel and press down over the razor blades, so that the blades fit basically like so, in the picture. Repeat for the remaing sets. Let epoxy set.
Using a Dremel and cutting wheel, grind the excess parts of the razor blade away, until it looks like the pic.
Now take your screwdriver, and cut the tip off of it. Take the pen collet and stuff the end of the screwdriver in it. After you are sure it fits properly, make it permanent using super glue. Now you can slip the blades onto the screwdriver, and when they get dull, you have replacements ready to go.
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
15 Comments
Excellent and clever 'ible. I don't have a grinder so am going to use the snap-off blades from a cheap box cutter (6 knives for a dollar at my nearby Just A Buck store). The blade tips snap off so you can always have a new sharp tip. They are scored so they break into tiny parallelograms. Small enough so I can KWIK epoxy them onto the pen tube. Thanks!
You could always strip wire with a razor. This is a great instructable.
Awesome, I've yet to ever lay down money for wire strippers. I've always been stuck with either my teeth or a razor blade and neither are fun or tidy looking.
what a genious idea! thanks
the blades are FLAT against the top so you have to cut semi cirles in the blade? (\/) ??? or are the blades pointing back towards the screwdriver
Yeah, the blades are flat and arranged in a V. You grind the blade AFTER epoxying it on the pen tube. I posted a couple action vids that should be active in an hour or so.
My teeth havent failed me yet :D
lol, wow, I'm glad I'm not alone. My wire strippers are fine for every kind of wire except the really tiny kind like this.
I had that problem with the small wire also. I used a large nail clipper and a small file to cut a v shape grove in the clippers. I had to do it a few time to get it just the righ size, but the errors work for other wires that are to small to strip. Works every time without a strand of wire cut...
for the 30awg specifically, the wire wrap tools they sell at RShack have a stripper that comes in the handle. I've had mine & used a lot over the past 10-12 years and it still works great -- though the stripper is really tiny & if you're not really careful about how you put away your tools you'll lose bunches of them. it probably takes more dexterity than this tool, and the coolness factor isn't nearly so high as this homebuilt one (-- and it's like $15 for the set).
