Predator Bio Mask - Pepakura (updated)
 by marshon
Featured
I made a Master Chief Helmet from Halo a couple of years back for a space girl shoot. I didn't really finish it to a high standard, just painted it up with all the facets still in place. Seemed to look OK to me, however I liked the Pepakura system so I decided to look around for a Predator Bio helmet design and I found this PEP file
Here
You will need the Pepakura Designer software which can be used for free with limitations. You can get the software
Here
I downloaded the PDO PEP files, then had to re-arrange it because I am using A4 card for mine and the PEP is set up for Letter. No big deal, just shuffle the bits around.
I did find a different PEP file set up for A4 AFTER I had finished this, so I may decide to build that as well later.
Step 1: Print, cut out and assemble
After you have downloaded the PEP file, use Pepakura to print it out onto card stock. I use standard card for this, it available at any good stationers or office supplies retailer. It's basically greeting card thickness, quoted in Europe as 180gsm, I don't know the US equivalent.
I used yellow card since that's what I had in stock.
This PEP came out at 8 pages. I began with the crown and worked my way downwards carefully cutting out the sections and gluing them together with general purpose glue.
Very fiddly, and time consuming. It took me two evenings of solid work to produce the card model. Some bits didn't seem to have quite the right contours compared to the movie stills I was using as a reference. The jowls seemed too flared out. I eventually put a strip of masking tape across the back to pull the mask into a better shape.
ibonka says: Oct 16, 2012. 1:52 PM
AWESOME!!!! pleaseeeeeeeeeeeeeeeeeeeeeeeeee could you give that PDF file to some other site where i could download it?? please i really want make this mask.
PS: sorry for my bad english
darklash582 in reply to ibonkaDec 31, 2012. 2:55 PM
you need to buy it after you did that you can download the pdf and it is worth it !
good luck with making it !!
darklash582 says: Oct 1, 2012. 12:48 PM
hello ,
when i want to download the pdf it always asks mmy password and when i inserted it i g back at the same page what do i do ??
, nice job i reaally love it !!
Mermaid716 says: Sep 17, 2012. 2:26 PM
Marshon !
Awesome job. Wanted to know if you have a supplies list of the
things you used so I can go shopping. Also, do you sell any of these?
Thanks, D :)
naig says: May 19, 2012. 10:31 AM
que buen trabajo se agradese
S.E.G15 says: Mar 26, 2012. 12:15 PM
I'm trying to download the PDF file but it jus keeps reloading the page wat do I do???
marshon (author) in reply to S.E.G15Mar 27, 2012. 1:57 AM
You would have to ask Instructables about that. i have no control over the website or downloads ...
titch1993 says: Nov 13, 2011. 11:44 PM
every time i press some thing it say insert password what do i do ?
BIGANDOS says: Nov 4, 2011. 2:32 PM
THINK I´LL GIVE IT A GO MYSELF
Jaxes says: Jul 28, 2011. 4:46 AM
great job...thanks for sharing
aidanjarosgrilli says: Jul 24, 2011. 5:11 PM
thumbs up X 200000
rasta mon says: Jul 12, 2011. 11:50 PM
AMAZINGGGGGGGGGGGGGGGGGGGGGGGGGG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
evstafievs says: Apr 21, 2011. 6:53 AM
I want to make motorcycle helmet whith the face of predator. Can you help?
marshon (author) in reply to evstafievsApr 21, 2011. 11:27 AM
That would depend on a number of factors. For example, are you talking about painting an existing helmet? Which is simply a matter of transferring a design onto the helmet and spraying it with an airbrush.
I very much doubt the legality (or safety) of actually trying to make an entire helmet for use on the roads without some sort of safety certification. You don't say what country you reside in but if it's within the EU then this would almost certainly be illegal.
It may be possible to make the mask as part of the helmet visor, but again I think the limited visibility would be a cause for concern.
stayalive says: Feb 28, 2011. 9:22 PM
PERFECTTTT DUDE
n1cod3mus says: Jan 28, 2011. 6:25 AM
Really good project you got there, are you doing the rest of the predator? I am in the process of doing the whole Predator, I have a biomask and have made my Latex Mask, I'm working on the body suit right now.
On my Biomask i have added LEDs as well but i have put them in with a switch to kill the circuit but also a reed switch as well and a magnet in the latex mask so when i put the mask on the LEDs turn on and when i remove the biomask they turn off automatically.
marshon (author) in reply to n1cod3musJan 29, 2011. 5:51 AM
Although I have to make up the dreds for this, the rest of the 'cotume' will be painted on to a naked girl. That's when I finally get around to it.
I'm considering making the shoulder weapon though .....
n1cod3mus in reply to marshonJan 29, 2011. 9:10 AM
I have found a good way to make dreads, you can buy pipe insulation thats about 25mm in diameter you it comes in a big real so you could cut it to length taper the end and put a weight in the end and coat it in black latex, done.
the shoulder weapon i have given some thought to, i'm thinking i will put a servo in it so i can make it retract to the safe position.
From what i can tell you use your stuff for photography so that wouldn't be required.
You could make the weapon from foam board by layering it up, and you can cut it using a polystyrene cutter or sharp knife, you could even make it out of polystrene
Reffner says: Jan 28, 2011. 11:52 PM
This is freakin' AWESOME! You did an outstanding job. I really wish I had the time and patience to do something like this. Way to go!!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
