Step 10: Compile and Run ADXL362_RaspPi
gcc -o ADXL362_RaspPi -I ../bcm2835-1.5/src ../bcm2835.c ADXL_RaspPi.c
sudo ./ADXL362_RaspPi
Which I combines into a script called compileADXL362.
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
(1) updated inputs (denoted by -I in command)
(2) updated the path from ../bcm2835.c to ../bcm2835-1.5/src/bcm2835.c
(3) updated file name from ADXL_RaspPi.c to ADXL362_RaspPi.c
