Prelude to Dry Nights
 by cptsilvertooth
Featured
This is my first instructable - I didn't plan on writing one, but about 1/2 way through my project I realized this might be helpful for other people so I'll try to catch you up on my pictures as best as possible.  I use a lot of parenthesis to explain the concepts (such as what I'm doing right now) so hopefully you'll be able to get the idea to do with your own scrap parts instead of just using what I used.
Some kids struggle to have dry nights longer than their friends do, and it can be very embarrassing for them with sleepovers, siblings, or just a bad feeling.  Although it can be frustrating for the parent who has to keep doing the sheets and cleaning up, this is never the kid's fault.  The major cause of bed-wetting is a very sound sleeper.  This can be caused by many issues - in our house it's because of a health issue that causes the "out like the dead" slumber.
One thing to point out - the device doesn't work on its own.  It's a partnership between you, the kid, and the device (we all ours R2).  The idea is the device goes off, the kid wakes up, associates the urination feeling with waking up.  With that, you (the parent) gets up, and instead of making it a disappointing thing (as in "too bad - another accident")  you make it a positive thing ("Great!  You got up!").  Additionally, show the kid the wet spot - it'll get smaller after a couple of nights as the kid wakes up sooner in the cycle, and seeing the wet spot shrink (AFTER giving said child time to go to the bathroom and change of course) will be a form of progressive encouragement.  I can't stress this enough - ALWAYS STAY POSITIVE WITH YOUR CHILD ABOUT THIS!  One negative comment or feeling is going to give the child an embarrassing association with the whole thing, halting the progress.
Name-brand companies have been making these and selling them for a TON!  This show you how to make it for ~$10
Special thanks to Jack Brockman who gave me this idea originally, and provided me with a couple of parts.
Onward ho!!!
Step 1: Gather Materials and Tools
Sorry again for the lack of pictures at this point - pictures didn't start until later :(
A part of this project was wanting to do it all myself with things lying around the house, but I'll throw some suggestions out there for the harder to find stuff.  This seems like a long list, but don't be daunted - it's all pretty easy to come by!
Materials:
  • Two ~4'x4' aluminum or copper screen (taken off of old windows or you can buy a roll very cheap @ Lowe's)
  • One and a half 1" PVC pipes (taken from my old sprinklers)
  • ~9' wire (I used old speaker wire pulled apart to make my pennies stretch!)
  • Some sort of electric bell or alarm (this instructable is with an analog bell, but you can make a digital one work).  Umm...this was from a junk pile...I don't know where to buy one
  • 9v battery (or whatever is appropriate for your bell) and battery clip/holder
  • A switch (can be simple 2 way switch - I used a 3 way pull switch that was sitting around, but any type of switch that a kid can easily operate will work)
  • Some screws
  • [optional] carpet padding
  • Last item - a box/container.  Only one rule here - can't be made out of metal.  Can be any size you want, but if you decorate it it will be a nice touch for your son/daughter
Tools:
  • A drill or screwdriver
  • A Dremmel (or other rotary tool)
  • Wire stripper or a knife (be careful - they are sharp!)
omnibot says: Dec 14, 2011. 6:53 PM
Good concept. I take it that the conductivity of the urine is letting all the power for the bell run trough the screen + urine? This could be a small shock-hazard, the coil in the bell could give some feedback that raises the voltage to a level where it could potentially give a small electric shock. A low-ohm electronic trigger would be a better choice. Number 6 on this page of touch triggers is the simplest one http://electroschematics.com/5996/touch-switch-circuits/ but most should work.
cptsilvertooth (author) in reply to omnibotDec 16, 2011. 7:10 AM
My concern about the shock led me to use a 9v instead of a transformer (you can feel a charge from a 9v on a wet tongue because it's so sensitive, but not a wet part of your skin).
We used it for about 2 weeks before we didn't need it anymore, and no shock was reported. Your idea does add an extra layer of protection though - thanks for that!
Cheers
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
